My 89 Trans Am gets hot and shuts off...no good
Old Apr 8, 2010 | 01:35 PM
BowtieBandit13's Avatar
Car: 89 Trans AM
Engine: L98 5.7
Transmission: 5speed
I start it up, the timing chain needs to be replaced and i never get it above 3000. It has a rough start til it warms up after about five minutes. It then starts to get hot and shuts off. I just got the car a couple days ago, alot of info about it under different thread. The 350 got swapped in from a 305, i dont know if they didnt connect all the sensors back up or backwards or if they are bad, or even whats wrong at this point. If you have any ideas or tips that would be great. Thank you.
Old Apr 8, 2010 | 01:38 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: My 89 Trans Am gets hot and shuts off...no good
is this a tpi? if so check the codes, also could be a problem in the distributor or injectors
Old Apr 8, 2010 | 09:39 PM
Car: 89 Trans AM
Engine: L98 5.7
what is the procedure to check the codes on these cars?
wayshegoes
Aug 17, 2015 12:00 PM
jackhammer
Aug 15, 2015 10:04 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
