New intake on questions about fittings?...
Old Apr 8, 2010 | 06:30 PM
acerocks666's Avatar
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
I just got my new 2101 performer intake on my 83 z28 and it is beautiful lol. I just have a few questions about the fittings for it. The first pic I attached is the 2 fittings I took off my old intake. The left one was for the heater hose but is to big for the hole in the second pic. The second just had a vacuum hose going to it and I'm not sure if I even need it anymore but it only fits in the hole behind the carb. Guess what I need to know is what size are the holes on the 2101 intake the 2 on front and 1 behind the carb so I can get the correct fittings or plugs for it. Also the 3rd pic is my old water neck. I was never sure what the wire connector or other fitting on top were used for or will I even need them anymore otherwise I will just get a new one to put on. Thanks for any help.....
Attached Thumbnails New intake on questions about fittings?...-dscf3576.jpg   New intake on questions about fittings?...-dscf3578.jpg   New intake on questions about fittings?...-dscf3580.jpg
Old Apr 8, 2010 | 06:58 PM
matt1970pon's Avatar
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
Axle/Gears: 3.45 g92
Re: New intake on questions about fittings?...
hey not sure of the sizes but you could get a mainfold plug kit from say pep boys or autozone.They have different sizes in them and one would fit..would tell you the side of it.
Old Apr 9, 2010 | 04:56 PM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
any thoughts on water neck?...
Old Apr 9, 2010 | 05:04 PM
one92rs's Avatar
Car: SOLD!!!!!
one my 92 tbi engine i had a water neck with no sensors. but it was cracked. so i went to the auto parts and got a water neck for a 69 camaro. the 92 camaro hose was a real tight fit so i ground the neck on the housing down slightly with a sanding wheel on a die grinder and it fit perfect.
Old Apr 9, 2010 | 05:29 PM
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
the neck itself fits on the new intake I just didn't know if I needed the sensors or not cause I haven't seen a new one with those fittings on it...
Old Apr 9, 2010 | 07:56 PM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
that might be the temp sensor for the ECM..not sure. Try going on autozone's website and looking up that temp sensor for a tbi car..
Old Apr 9, 2010 | 08:29 PM
one92rs's Avatar
Car: SOLD!!!!!
temp sensor on my tbi is on the head itself. now one of those might be the fan sensor
Old Apr 10, 2010 | 07:30 AM
Car: 1987 iroc z
Engine: 305 tpi
Transmission: MM5
where are the wires going? can you trace them back?to the fuse panel or whatever..
Old Apr 10, 2010 | 07:35 AM
one92rs's Avatar
Car: SOLD!!!!!
after looking at the picture again does it have electric fans or a mechanical one. the single terminal one could be the gauge. the two wire is a sensor for either the ecm or electric fans.
Frozer!!!
Jan 19, 2024 04:55 PM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 15, 2015 11:56 PM
