key wont turn
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
Re: key wont turn
make sure its in park...try to just turn it back and forth a little and pull slightly..mine does that sometimes.
Car: 88 trans am
Engine: 350sb
Transmission: t400
Axle/Gears: 7.5/2.73
Re: key wont turn
Its in park, and the steering wheel is locked, come on now.
I swapped my 305 tbi for an older 350 sbc, I took my ecm out cause I won't be using it anymore, removed all the useless sensors and got a new transmission and shifter. When I hooked my battery up and went to start it my key wouldn't turn
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: key wont turn
You mentioned shifter ... you know there's a lock mechanism in the stock shifter setup that ... unless is unlocked (ie shifter in park) it keeps the key from turning, right? It's a cable I think that moves something within the ignition cylinder keeping it from turning - could that be the problem? It runs up through the dash and into the column.
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: key wont turn
New trans & shifter---That info probly woulda helped in the first place.
IIRC, another member had issues putting in a B&M.
OK.. so you obviously know what's next..
Trans & shifter maker.
Understand that this info MAY BE IMPORTANT!! Members have done all kinds of swaps & faced MANY issues, & it MAY BE that some one has faced this issue exactly, & got things working.
..... Last edited by t-top havoc; Apr 9, 2010 at 07:21 PM. Reason: NVM
Car: 88 trans am
Engine: 350sb
Transmission: t400
Re: key wont turn
I have a built t400 and a turbo scs shifter, I looked for a sensor on the wiring diagram but I couldn't find it. Where does it run after the column?
The solution for this was lowering the steering column about 1/4" so the lock cable couldn't press down.
