help me change my spark plugs
Old Apr 18, 2010 | 02:50 PM
joekaz1070's Avatar
Car: 1987 Trans am
Axle/Gears: GM 10 bolt
I want to change my own plugs. If anybody could share thier experience changing plugs ,I could use the help. Did you put the car on ramps and get them from the bottom? Or access them from the top?,etc. Any details would be appreciated. My car is a stock 87 TA 305TPI
Old Apr 18, 2010 | 03:09 PM
greatskiiiier's Avatar
Car: 98 z28
Engine: ls1
Transmission: t56
Axle/Gears: 12 bolt/ 4.11
Re: help me change my spark plugs
go from top, use spark plug socket with extensions, if you need use some universals too
not a hard job
Old Apr 18, 2010 | 03:18 PM
joekaz1070's Avatar
Car: 1987 Trans am
looking down it seems pretty tight. also people keep scaring me saying if the plug breaks you are hit. I know the ceramic could break but would that mean I could not get it out ? Thanks for your response
Old Apr 18, 2010 | 03:49 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
If the ceramic part breaks you are still fine as long as nothing falls into the cylinder. To date, I've never had the ceramic part break in way that anything would fall into the cylinder, just sometimes the ceramic shaft will break. This is a rare occurrence though. You should be fine, just use some common sense.
Old Apr 18, 2010 | 03:53 PM
BigBadGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 350TPI
Axle/Gears: 3:27
I had to change the plugs in my 5.7L GTA with A/C and air tubes and its not a fun job at all. I remember I did have to get at a few of them from the bottom. The air tubes stink...
Old Apr 18, 2010 | 06:16 PM
john69er123's Avatar
Car: 1985 z 28
Engine: 400 small block
from the top i change mine myself because i trust very few people when it comes to working on my car some of them you will need a 1/2" ext. some of them you wont get to with it so you might have to take it on and off just make sure your arms stay away from the heat shield it will cut your arm and not feel so great
Old Apr 18, 2010 | 06:42 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
When I had stock manifolds, AC, smog and whatnot, I did most of them from the bottom.
I've got small hands and had issues going from the top.
Old Apr 18, 2010 | 06:58 PM
edpontiac91's Avatar
Car: 1991 Formula 350, 2002 Grand Prix G
Engine: 350 with SLP & Edlebrock mods
Transmission: 4-speed automatic-700 R4
Axle/Gears: 10 bolt with 3:73
I have done mine several times (and I have Edelbrock TES headers) and it is a PITA. The last two rear plugs on the passenger side can be done by going UNDER the car and looking straight up by the starter. I have found that a cut-down spark plug socket (with a 3/4" open end) works the best. Just slip is over the plug and use a SHORTY 3/4" wrench. Trying to get into those tight spaces with sockets and extensions and swivels is VERY hard to maneuver with all the lines and hoses in the way.
Old Apr 18, 2010 | 08:15 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
you can break the stalk entirely off and it wont cause you any grief. The section you need to remove from the cylinder heads is all metal.
If they are hard to remove try hitting them with some penetrant and letting it sit. If you have factory exhaust manifolds some of them may need to be removed from underneath the car. That being said none of them are impossible and you shouldn't have too much of a hard time.
Old Apr 19, 2010 | 09:25 PM
screamnchickn's Avatar
....not sure if you got this taken care of yet or not but heres a tip just in case... The ones on the passenger side is easier to reach from below... and added to the spark plug socket you can use an end wrench to turn the socket easier.. it really works and helped me out a lot, some people dont take full advantage of the hex end on the top of the socket! but Good Luck! hope I was able to help ya out!
Old Apr 19, 2010 | 09:41 PM
Zepher's Avatar
I did my plugs today while I was changing the wires and had to cut about 1/4" off of the socket to get it on 2 of the plugs with my Hooker Headers.
I used to have the SLP spark plug tool, basically a sparkplug socket that was cut down really short, but someone misplaced it.
Old Apr 19, 2010 | 11:45 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
its simple bro just do them all from the bottom. put the car on stands and you may have to change the position you lay in but overall its a pretty easy job
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
