What the hell engine is it?????
Old Apr 23, 2010 | 08:23 PM
stlcamaros's Avatar
I recently picked up what I THOUGHT was a TPI 350 engine.....now I don't know and I am majorly confused by what I am finding. Can you help???
The block casting is 14093638 which by all indications says it is a 350 block. On the drivers side of the block behind the head on the bellhousing is a "GM 5.0L" code, 305? it also has an 89I1 stamp as well. Then I checked the heads and the heads are stamped with the 305 head stamp 14102187. I am majorly confused here.... a 14093638 block with 14102187 heads????? Does this make sense to anyone?
Did GM used some of the 350 stamped blocks for the 89 305 Irocs? That's what this engine is supposed to be out of..........perplexed.
Dean
Old Apr 23, 2010 | 08:31 PM
Twin_Turbo's Avatar
Re: What the hell engine is it?????
GM 5.0 says it all, it's a 305
Old Apr 23, 2010 | 08:33 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
There's nothing stopping someone from putting 305 heads on a 350. Something is wrong with your block casting numbers. There's no way a 305 and 350 can share the same block casting. The bore size is too different.
If you don't trust the casting numbers, you'll have to pull a head to see how big the bore is. Although the block casting number says 350, all the other numbers indicate it's only a 305.
Old Apr 23, 2010 | 08:35 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
take it back and try to get your money back
Old Apr 23, 2010 | 08:42 PM
stlcamaros's Avatar
I thought the exact same thing, but it's there stamped plain as day, 14093638 on the pass. side and then on the drivers side is GM 5.0L.......I don't get it.......I thought maybe it was a 350 until I saw the heads stamped with the 14102187 #. How could such a mistake be made by GM in stamping the block with 2 totally different engine sizes?????
Old Apr 23, 2010 | 08:49 PM
Ca[maro]88's Avatar
they produced HOW many 350's and 305's?? somebody just sneezed and pushed the wrong button.
Old Apr 23, 2010 | 08:50 PM
Ca[maro]88's Avatar
you must have gotten one of those engine that was built on friday at 2:59 pm lol
Old Apr 23, 2010 | 09:01 PM
stlcamaros's Avatar
I agree but I doubt this is a problem that you would see a lot of......GM does have SOME quality standards........
Old Apr 23, 2010 | 09:02 PM
stlcamaros's Avatar
I guess I'm really looking to see if someone knows if GM used 350 blocks for 305 engines. I know the blocks are the same but I am talking about a blocked stamped as a 350 but used for a 305.........
Old Apr 23, 2010 | 11:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You can't use a 350 block for a 305. The casting for the bores is completely different.
Old Apr 24, 2010 | 07:27 PM
stlcamaros's Avatar
Pulled the head today........it's a 305 engine. I'm pissed! I did my research before buying and the 14093638 casting number on this block was wrong! Oh well....I sold this engine to my brother and got my money back so at least I'm not out anything except the time to go get it........if you can't trust the casting number I guess the only way to know for sure is to pull the head.......the bore measured, with a tape measure, right around 3.75 inches
Old Apr 24, 2010 | 08:22 PM
RazorN8's Avatar
Car: 1987 camaro
Engine: 383 AFR heads
Axle/Gears: Ford 9" 3.70:1
The numbers on the drivers side bell housing are raised which means they were cast in the same process as the bores. These numbers will ALWAYS be correct. Keep that in mind next time you buy an engine. The stamps can be screwed up because they are put on later in another operation by another operator.Maybe I saw that wrong...were the raised numbers incorrect? That is a big bad on GMs part
Old Apr 24, 2010 | 09:26 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
lmao
Old Apr 24, 2010 | 10:52 PM
stlcamaros's Avatar
There are 2 sets of raised numbers....the passenger side casting number of 14093638 and then the drivers side "GM 5.0L"............
Old Apr 24, 2010 | 11:32 PM
Ilike2stroke383's Avatar
Car: 1987 Gta Trans Am
Engine: 383 Stroker
Transmission: t-56
Axle/Gears: 3.47 02 SS rear end
Dean
Does it have a t5? maybe someone put 305 heads on it and used the bellhousing from the 305 also because no 350's came with t5s
Old Apr 26, 2010 | 08:18 PM
RazorN8's Avatar
Car: 1987 camaro
That's just amazing. Sorry to hear about your luck.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
gta power
Aug 13, 2015 06:15 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
novaderrik
Aug 10, 2015 12:44 PM
