Help me pick out a Cam kit for my '85 Trans Am!!
Old Apr 26, 2010 | 07:57 PM
david_beast's Avatar
Car: 1985 Trans Am
Engine: 350 Small Block
Hey guys, I really want to put a cam in my car because I love that lope,I really want something loud and want my car to lope really good.What cams would you suggest??I have no experience in this and I have no idea which one i should go with,Please help me pick out one!!I would really aprreciate it if you have some kind of video so that i could listen to it and pick out one.
Would this make a difference in gas mileage?
Car Mods:
350 bored .30 over chevy small block
Holley 600 Carb
High rise Intake
Stock headers
Mild cam
Flowmasters Exhaust
700 R4 Transmission
I am a beginner in cars and have no experience in working on them,so I am not an expert lol
Thanks for you help!!
Old Apr 27, 2010 | 04:06 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Re: Help me pick out a Cam kit for my '85 Trans Am!!
Cams are often one of the most mismatched parts for a lot of engines, and there are a lot of factors to consider when choosing one.
First and foremost, what do you want the car to do? Do you want it to have tons of torque on the bottom end and be a good street runner, or do you want more top end power for a little more track oriented application?
What style block do you have in the car? Is the block machined for a hydraulic roller cam, or does it use the flat tappet?
Do you have the stock torque converter?
What's your rear end gear ratio?
What's the approximate weight of the car?
What is your compression ratio?
What's your rocker arm ratio?
And one of the most important questions, what heads are on the engine? What size valves? What size valve springs? What size combustion chamber? Are they aluminum or iron?
These things all need to be taken in to consideration when selecting a camshaft for your application.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Terrell351
Jun 13, 2021 01:13 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
