Good idea to go with LS2?
Old Apr 29, 2010 | 10:51 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I have been throwing the idea around to go with a Iron block ls2 motor making it into a 383 or a 402. Anyone have any experience with the ls2 motors in our cars fitment wise (i.e. headers, intake, ecm, tuning, ...)
Thanks for the incite,
Chas
Old Apr 29, 2010 | 11:43 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Good idea to go with LS2?
incite? what, a riot? Here's my lack of insight..How do you get to be a senior member without knowing to post this in the engine swap forum of TGO?
There are no iron block LS2s, the only way to have that is to put the #243 heads on an LQ9, then change the cam. If you add a stroker crank, you get 402 cubes. If you also bore it, you get a 408. All your other answers are in the stickies over in the LTx and LSx sub-forum. This is why it's there.
Old Apr 29, 2010 | 05:07 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Wow i have no idea what i was thinking...I have been looking at too many different forums. I was for some reason thinking that the LQ9 motor and ls2 were the same but its the ls1 motor and lq9 that are the same except block material.
My spelling on the other hand needs a little work..the best part is that spell check didn't catch it...
My bad ill post in swap section.
Thanks for the help haha
Old Apr 29, 2010 | 05:14 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
it happens to the best of us lmao
Old Apr 29, 2010 | 05:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Nope, you're having an off day. No big deal. LS1 is 3.898" bore, LQ9 is 4.000" bore. LS2 is 4.000" bore. 1 & 2 are aluminum blocks. 9 is iron. LQ4 is LQ9 but dished pistons. Shall I go on? :-)
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Cripley
Aug 17, 2015 03:35 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
Thirim
Aug 13, 2015 03:09 PM
