Emission problem
Old May 3, 2010 | 06:27 PM
Tryon's Avatar
Car: '83 camaro z28
Emission problem
I have a 83 z28 that has a 305, problem is that the car always reaks of gas and most likely the problem is that someone took all of the emission control junk and ripped it out. I have a question to whether i save up to buy a new engine or if i buy emission control stuff. Also if i buy a new engine i am only 16 so i dont know much about cars yet so that would be a good learning process. Also how much of a budget would i need for a new engine?
Old May 3, 2010 | 07:31 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Emission problem
just replacing the engine isn't gonna solve the fuel vapor issue.
Old May 4, 2010 | 12:19 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
if you have emissions tests, youll need the emissions stuff whether you build a new motor or not. unless you find an inspector willing to "take tips".
Old May 4, 2010 | 12:38 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
the 83 is mechanical advance? or is it controlled by a computer... all you may need is a tune of your Carb and or timing...
Old May 4, 2010 | 08:09 PM
Tryon's Avatar
Car: '83 camaro z28
pretty sure its all mechanical
Old May 4, 2010 | 10:15 PM
thedrewdotcom's Avatar
Car: 1986 IROC
don't waste your time by putting air injection on unless you have to because of emission laws. do you have any codes set?
Old May 9, 2010 | 10:59 AM
Tryon's Avatar
Car: '83 camaro z28
how would i fix the emissions,because im tired of smelling like gas all the time and people that follow me tell me that you can smell gas to
Old May 9, 2010 | 03:20 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
well if you don't have a computer on board, then you will have to take it to someone who can adjust your air/fuel mixture... if you do have a computer on board, then you will need to again have your carburetor adjusted and replace some sensors...
Old May 9, 2010 | 05:56 PM
xX89RSXx's Avatar
Car: 1989 Camaro RS
Engine: 305 TBI
Where is the smell coming from? Under the car, under the hood, or the tank area?
Old May 9, 2010 | 09:03 PM
Tryon's Avatar
Car: '83 camaro z28
umm idk i will check our where the smell is coming from all i know is that i start it up and it smells like gas when im driving and when i get out i smell like gas
Hotrodboba400
Dec 10, 2019 07:07 PM
andy74
Sep 3, 2015 08:41 AM
GeneralIesrussi
Sep 3, 2015 03:23 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
greenyone
Sep 2, 2015 03:39 PM
