Got fuel and spark.....car won't start
Old May 9, 2010 | 06:12 PM
POP6482's Avatar
Car: 1989 Iroc-Z Convertible
Engine: 6.0 LQ4 LSX
Axle/Gears: Moser 12 bolt w/4.11s
305 TPI
went to a cruise last Wednesday got in to leave and it wouldnt start. Car turns over and over not even trying to start. Now the confusion begins!
Here is what I've checked so far:
Got spark at coil and plug
Fuel Pump is engaging
Fuel pressure is up
No codes being thrown except 12 which means ECM is working
New injectors put on last year
Any help would be appreciated
Old May 9, 2010 | 06:34 PM
SSZ2891's Avatar
Re: Got fuel and spark.....car won't start
are the injectors squirting? only thing i could think of is that the pump is engaging but maybe injectors arent working?? just a wild thought not too sure
Old May 9, 2010 | 06:39 PM
SSZ2891's Avatar
you have fuel and spark but do you have compression? i doubt it would be that seeing it was driving fine previously though. a compression test wouldnt be a bad idea tho
Old May 9, 2010 | 06:54 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
Try spraying some carb cleaner down thru the intake and see if it fires up...if it does then your lacking fuel. Did you check your oil for gas to make sure you dont have a stuck injector flooding out the motor?
Old May 9, 2010 | 06:56 PM
one92rs's Avatar
Car: SOLD!!!!!
put some gas on a rag. remove the air cleaner tube to the throttle body. hold the soaked rag in fron of the intake WITHOUT LETTING IT GO and see if it starts.
Old May 10, 2010 | 05:12 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
just went out to the gargage and sprayed carb cleaner through the intake and the car fired right up. Throttle was a little hesitant at the start. Took it for a ride up the street and seemed to clear up. I turned the car off and started it multiple times without any problems. I am leaning towards the injectors not delivering enough fuel during ignition. My brother and I are going to check them in a little.
Thanks for everyones help.
Old May 10, 2010 | 06:21 PM
POP6482's Avatar
Engine: 6.0 LQ4 LSX
Turned out to be the TPS. After the car was running, I checked for a code. Got a code 21.
THANKS AGAIN!
Old May 15, 2010 | 10:56 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
THANKS AGAIN!
glad to see you got her running
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
