87 iroc burning rubber on its own!!
Old May 11, 2010 | 07:58 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
Transmission: TH700-r4
Hey, i have a 1987 iroc z 5.7L automatic.... when i place the car in drive from park, the tires spin and chirp without even touching the accelerator.... Is the idle too high or what? im by no means a mechanic so any advice would help! thanks!
Old May 11, 2010 | 08:52 PM
92RSMoneypit's Avatar
Car: 92 camaro B4C
Transmission: t5
Re: 87 iroc burning rubber on its own!!
What is your RPM in park.
Old May 11, 2010 | 08:55 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
not sure, im away working now and just got the car working again... it will be 2 weeks before i get home to see what it is.... do you think it could be a high idle? or what else could it be?
Old May 11, 2010 | 09:54 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
My 89 has the tightest torque converter I've ever seen in a car. Same deal as your car, and sitting at a red light I often put it in neutral to let the engine idle smoother. Just the way they're built I suppose.
Old May 13, 2010 | 04:20 PM
z28maro91's Avatar
Car: '83 z28/'85 iroc
Engine: L69/LB9
Transmission: 700r4/700r4-b&m shift kit
Ive been having the same problem to, haha and my tach doesnt work so i dont know what my rpms are when im in park.
Old May 13, 2010 | 07:28 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
when i get home in 10 days i'll check the rpms in park and let you know. Thanks
Old May 13, 2010 | 07:34 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
The idle for the TPI is computer controlled via the IAC valve on the throttle-body. It sounds like your IAC may be malfunctioning. It could possibly be other problems as well, such as a sticking throttle blade, a large vacuum leak, or a faulty sensor. Your IAC is the best bet to start troubleshooting though.
Old May 13, 2010 | 07:40 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
ok, so i'm pretty much the furthest from a mechanic as you can get.... Does this seem like a serious problem or do a lot of cars experince this? I have been having a lot of trouble with my car and just got it running again.. so i hope this isnt something too serious.
Old May 13, 2010 | 07:42 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
IAC problems are very common, and they are not serious. Hopefully, that's all it is.
Old May 13, 2010 | 07:45 PM
87iroczeh's Avatar
Car: 1987 Iroc Z
Engine: 5.7 L TPI
ok.. thanks for the help... but how do i check this valve and determine if it is the problem?
Old May 13, 2010 | 08:23 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
There's some info here:
https://www.thirdgen.org/tpimod2
There are some example videos on youtube.
The IAC is fairly easy to remove and inspect.
The IAC and its port are often very dirty and sometimes respond well to a good cleaning. You can test the IAC while removed (but plugged into the harness) by having a friend turn the ignition key from off-to-on, and then off again. The pintile will move in and out.
1992 Trans Am
May 10, 2023 07:19 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
