my engine setup what do you think??
Old May 13, 2010 | 03:59 PM
rx8camaro's Avatar
ok guys i am looking for a range 400 or 450hp. I have a 1992 350 L98. Going to leave engine stock. then have my stock heads port and polish with valve job. Change intake to a FIRST manifold setup. hooker headers and exhaust. Finally procharger. professionally tuned. i realize other parts of the car need to addressed but this is just a starting point on where to go with the engine setup. let me know what you think or should change. There is a budget involved here of course lol. thanks guys.
Old May 13, 2010 | 06:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
How much boost? Staying with a stock cam, or something for the charger?
Old May 13, 2010 | 07:33 PM
rx8camaro's Avatar
Re: my engine setup what do you think??
i just want to run minimal boost 6-9psi i think the basic kit runs. I was under the impression that you cant run to much lift and stay with stock heads so i wasen't even going to change the cam. unless you know of a good product or i could get something custom i guess. i can run to much boost if my bottom end won't be forged.
Old May 13, 2010 | 07:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Stock cams work well with boost. The intake upgrade isn't absolutely necessary, but you might want to plug off the EGR and PCV ports.
I like to fill the EGR passages in the center exhaust ports with weld before I begin porting stock heads.
For boost, basically you just need a good set of larger injectors, a great exhaust system, and a very good tune.
I would get with your tuner and work out the details with them.
Old May 13, 2010 | 08:07 PM
rx8camaro's Avatar
do new injectors usually come in the supercharger kit? I was thinking 36lb if not. How can i locate a good tuner in the central pa area. Is there a website listing or does anyone know of any. I wouldn't mind a drive to find one thats good.
Terrell351
Jun 13, 2021 01:13 PM
masonta
Aug 31, 2015 10:14 PM
Street Lethal
Aug 13, 2015 08:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
