L05 roller cam swap
Old May 14, 2010 | 07:10 PM
Theman0188's Avatar
Car: 76 Corvette Stingray
Transmission: TH350
Axle/Gears: Stock
L05 roller cam swap
I have a L05 3638 block, with a flat tap cam. It has the provisions for a roller cam and i am almost done swapping a lt1 cam in it. i am missing one part... the cam retainer plate. I got one sent from a 305 tpi engine and it didn't fit. the plate was not long enough to line up with the bolt holes. I dont know where to get one, so i am at a dead stop. Can someone help?
Old May 14, 2010 | 08:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: L05 roller cam swap
Try a dealership
There are two different retainer bolts patterns
Part # 10088128
Camshaft Retainer First design with 3.62" bolt center as used on ZZZ, ZZ1 and ZZ2 engines. 1988-1990 engines use # 10088218 with 3.620" bolt pattern.
Part # 10168501
Camshaft Retainer 2nd design with 3.294'' bolt center
Used with ZZ3 & ZZ4 Engines. Also Used on 1996-2000 L29 454 Big Block Chevy And 454, 502 GM Performance Parts Engines With Roller Camshafts & Gen VI Block.
Old May 14, 2010 | 10:57 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
yeah i have looked at each one and i dont know which to get. My guess would be one i have was the first design because it came from a 86-88 tpi engine. I guess that my l05 came from a 88-92 truck, so you would think the first design would fit since the second one says 1996-2000.
Old May 15, 2010 | 02:17 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Measure across the retainer bolt holes in the block
Old May 15, 2010 | 05:39 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
In case you do not have upgraded the timing chain, the GMPP 12371043 chain kit comes with both style retainer plates.
https://www.thirdgen.org/forums/tech...2371043-a.html
Old May 15, 2010 | 02:57 PM
Theman0188's Avatar
Transmission: TH350
Axle/Gears: Stock
I measured across the bolt holes (between the outside edge of each hole). it was just right under 4in. The retainer plate i have measures just above 3.75in.
Thomas1976, i already have the correct timing belt, but in the pic on that link i know i need the plate on the left, and i have the one on the right. The only problem is the dealerships photos look the same to me.
i greatly appreciate the help guys
Old May 15, 2010 | 09:58 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You measure center of hole to center of hole and match it to the retainer measurements I gave above.
I listed the GM part numbers and the measurements above. Go by that , not pictures
Old May 19, 2010 | 02:20 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
there are TWO ones used,i had the same prob when building my LB9.it sounds like you need the early style,measure bolt hole to bolt hole i got mine from the local chevy dealership good luck
junkcltr
Aug 2, 2019 11:12 PM
MoJoe
Sep 24, 2015 09:12 PM
camaro71633
Sep 1, 2015 10:24 AM
anesthes
Aug 8, 2015 09:37 PM
