Help identifying heads
Old May 16, 2010 | 10:48 PM
bluegizmo1983's Avatar
I need some help identifying my cylinder heads... I pulled the valve covers got got ALL of the numbers/casting/codes from the heads, but when I search for the findings I come up with nothing...
There are only two numbers/codes on the heads and they are:
GM14T
C26 76
the code "C26 76" is stamped exactly like that on the head, with the space between the numbers. I double, triple, quadruple checked that those letters and numbers are exactly what is on the head and nothing else. Everything under the valve cover is pretty clean and there is not evidence of numbers being filed off or anything like that... Engine is a 350ci, not sure exactly what the block casting numbers are, as they are hidden behind my AC bracket and I haven't had the time to remove all that to get to the block casting number.
Old May 16, 2010 | 11:32 PM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: Help identifying heads
thats not enough numbers. When you pull the valve covers, the casting number should be right in the middle. This will help you find the numbers, and here is a list of casting numbers up to 1993.
Old May 16, 2010 | 11:43 PM
Those numbers or anything like it don't exist on my heads... at least on my driver side head...
Old May 16, 2010 | 11:45 PM
travis401's Avatar
Car: 91 Camaro RS
Check the other head. Maybe the ones on the driver side wore off somehow.
Old May 16, 2010 | 11:48 PM
travis401's Avatar
Car: 91 Camaro RS
The "GM14T" looks like the beginning of the number. GM has heads from the 80's that start with a 14, but the T could be a worn number maybe?
Old May 17, 2010 | 06:08 PM
Thanks for the replies. I'll pull the other valve cover when I get some time and check that head... I'll take some good high quality photos too and post them.
The GM14T is on the driver side head, near the firewall end of the end, just between the last and 2nd to last valve springs (closest to firewall). The numbers/letters arent all the same size though, the G is small, the M14 is about twice the size as the G, and the T is the same size as the G. If that makes any since lol.... basically its like this, but all uppercase: gM14t.
the other numbers I saw, the C26 76, if I'm correct that is the date code. So they heads were built March 26th 1976?
Old May 17, 2010 | 06:39 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
they could be some old aftermarket heads. or maybe there is sludge covering the numbers.
Old May 17, 2010 | 10:05 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Best way to get an answer here - take a pic of one of the heads with the valve cover off.
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
