Pro magnum sa rocker/valvecover clearance
Old May 18, 2010 | 05:50 AM
z 28 jari's Avatar
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Do comp pro magnum rockers(1.6 ratio) fit under stock centerbolt valvecovers,or should I buy taller covers?Would they fit under proform valvecovers(1/4" taller than stock) http://www.jegs.com/i/Proform/778/141-130/10002/-1
Old May 19, 2010 | 01:17 PM
david chambers's Avatar
Car: 1986 iroc Z-28
Engine: "LB-9" TPI 305
Transmission: 700-R-4
Axle/Gears: corporate 2:73-1
Re: Pro magnum sa rocker/valvecover clearance
the mounting pedistals may need clearance machining for safetys sake i would go with taller covers but you can measure to be sure
Old May 19, 2010 | 04:42 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
if your talking about pn# 1416-16 ? they fit fine under stock valve covers . i have used them before and have them on my current ride . good luck .
Old May 20, 2010 | 10:02 PM
CanuckBird's Avatar
Car: 83 Z28
Engine: 355
Axle/Gears: 3:73
Yes they will fit but the tall covers look better!
Attached Thumbnails Pro magnum sa rocker/valvecover clearance-dsc00077.jpg
Old May 21, 2010 | 09:32 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
They wouldnt fit under mine without clearancing so I got tall valve covers.
Old May 24, 2010 | 04:01 AM
z 28 jari's Avatar
Engine: 385
Sorry,first post was limited info.They are comp 1318-16
http://www.jegs.com/i/Comp-Cams/249/...rentProductId=
Old May 24, 2010 | 02:29 PM
Car: 1992 Camaro RS
Maybe these other guys have magical valve covers, or just clearanced them, but they just werent going to fit over my rockers:
They would hit the support braces on the inside of regular centerbolt valvecovers.
Old May 25, 2010 | 04:34 AM
z 28 jari's Avatar
Engine: 385
Infernalvortex,which covers did you use?
Old May 25, 2010 | 05:41 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I had the same problem on mine. I bought the "black crinkle" centerbolt valve covers with the red chevy emblem for mine and I had to have the machine shop notch the support braces inside to get them to fit and I'm only running the stocker 1.5 Pro-Comp Magnums. Seems the tall valve covers don't have this problem.
Old May 25, 2010 | 10:12 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I ran into the same problem with the stock valve covers not fitting, I imagine if I went and got a thicker gasket it would work cause it's very close.
But I went out and bought the same valve cover your looking at, they are more like 1/2 taller and work great. My only beef with them is the wiring harness for passenger side will not slip back into the stock location between the runners and valve cover if your running a TPI setup.
Attached Thumbnails Pro magnum sa rocker/valvecover clearance-img_0833.jpg
tmellott89
Oct 14, 2015 02:06 PM
Jorlain
Oct 8, 2015 01:57 AM
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
djmarch
Oct 2, 2015 10:41 PM
