ticking sound from intake
Old May 21, 2010 | 09:52 PM
jappryor's Avatar
i have an 82 t/a with a 305 carb engine.here is some back ground i bought this car a few months ago it is supose to have only 46,000 miles and it does look it. but here recently there has been a ticking noise, at first i thought it was one of my lifters i tried to ajust or tighten but that didnt work, put some seafoam in oil and ran it a couple of days then changed oil, and put that mysteria oil in also, still has ticking, i put a long screw driver to valve covers there is a very faint ticking coming from them, then put it to the intake then it got louder, any ideas guys or gals, sorry for long form just wanted all the info i could think of. what can i do about this thanks
John
Old May 22, 2010 | 01:47 AM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: ticking sound from intake
exhaust leak.....i know it doesnt sound realistic but mine did the same thing and i thought the same as you. try tightning your headers
Old May 22, 2010 | 07:24 AM
game1939's Avatar
Car: 91 chevy camaro
Engine: 383
Transmission: 700r4 built with corvette servo
Axle/Gears: posi 3:73
Old May 22, 2010 | 10:52 AM
jappryor's Avatar
i dont have aftermarket headers or you talking about the exhaust mainfiolds?
Old May 22, 2010 | 02:32 PM
game1939's Avatar
Engine: 383
manifolds or headers, even check pipe and manifold gasket
Old May 22, 2010 | 02:43 PM
kjvail1204's Avatar
Something else just food for thought, check your flex plate for cracks, mine made the click, and I did just about everything you did, checked valves, added tranny fluid to oil to get it to leave, didnt work. There is nothing but push rods and lifters directly under the intake. It coudl be ticing somewhere else and just mvoing threw the motor....
Old May 22, 2010 | 02:46 PM
game1939's Avatar
Engine: 383
Old May 23, 2010 | 11:38 AM
jappryor's Avatar
ok i hate to say it but im not familier with the flex plate, or where it's located could you hepl me please. thanks john
Old May 23, 2010 | 09:18 PM
kjvail1204's Avatar
LOL its between the motor and the transmission, its what the starter turns to get the motor started... you might have to drop the trans just to get a good look at it but then again you might not mine was so bad when I took the bolts out that held it in place the center hole stayed in palce and the flaex plate droped it was bad.... good luck
Old May 26, 2010 | 02:23 PM
kjvail1204's Avatar
Any updates yet??
Old Jun 9, 2011 | 07:54 AM
kjvail1204's Avatar
Would love to hear and update, to see what you found out??
Old Jun 9, 2011 | 08:05 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
could be the injectors ticking.
db057
Sep 4, 2015 07:57 AM
DJanes97
Sep 1, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
mustangman65_79
Aug 8, 2015 12:07 PM
mustangman65_79
Aug 7, 2015 09:55 PM
