car squeaking all the sudden..help
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
ok...me and my dad changed my rear shocks out for KYB GR-2's and now theres this squeek everytime i run over a pebble
seems to be coming from the drivers side rear...thought it was the spring but idk....
Mike
seems to be coming from the drivers side rear...thought it was the spring but idk.... Mike
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Re: car squeaking all the sudden..help
My old shocks would squeak everytime I would even touch the car. Maybe hit the shocks with a bit of lube?
Not too sure...
Maybe some silicone spray, or white grease?
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Could it be your polyurethane bushings? You may need to lube them.
Engine: 5.7 350 TPI
autozone has white lithium grease spray or somethin like that...would this work??
Car: 87 IROC Z28
Engine: 355 cid TPI
Sorry for the slow response. The sray lithium grease should work atleast for the short term. It should certainly verify that your bushings are the source of your noise. For long term cure you may need to detach the trailing arms and lube the faces of the bushings where they run against the brackets with graphite synthetic brake lube. Its the best product Ive found for this.
Linson
Aug 21, 2015 02:12 PM
