mild 305 build questions
Old Jun 2, 2010 | 10:04 PM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
so i got this plan to build the 305 in the bird im buyin. it has the L03 in it with a 700r4 behind it. i want to put a set of headers on it, a set of vortech heads, some roller rockers, an lt1 cam, and a weiand stealth intake. what kind of #s should i expect to see at the wheel with a good tune with this? ill be swapping in a t-5 sometime after this, so i dont want to put any cash into the tranny.
Old Jun 3, 2010 | 08:53 PM
Gibson's Avatar
Engine: LB9
Re: mild 305 build questions
nothing?
Old Jun 4, 2010 | 08:57 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
I doubt anyone has chassis-dynoed a combo like that. Be sure to have the Vortecs milled as far as your local machine shop says is safe, because if you don't mill them, you'll be under 8.2:1 compression. Also use Fel-Pro steel shim head gaskets.
Old Jun 4, 2010 | 01:24 PM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
With the milling as Atilla suggest to get at-least 9.0 compression DD2000 predicts 330fwhp with all things being perfect. You also need to consider if you are keeping the TBI (you didn't say) that it will need custom tuning, and upgrades to fueling (injectors, fp regulator, etc).
In reality though you will probably be getting 250rwhp once all the accessories and drive train are added to the equation.
Old Jun 4, 2010 | 01:56 PM
Saabster's Avatar
Car: 89 Camaro RS
Engine: LO3 TBI
Transmission: 700R4 => WC T-5
Axle/Gears: 3.42 Open Diff
Do a mild rebuild with SpeedPro flat top pistons. Then you won't need to mill the crap out of the Vortecs to get decent compression.
Old Jun 4, 2010 | 02:31 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
059 casting 305 vortec heads would not require milling.
http://www.aaeq.net/Enginequest/Cyli...tock/chevrolet
CH305A
Old Jun 4, 2010 | 04:51 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
CH305A
But they're no better than 081s, either. In fact, there are even swirl-port Vortec 305 heads, and I'm not sure which casting number goes to which version.
Old Jun 4, 2010 | 04:53 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
FWhp being flywheel horsepower. This is confusing, as the import crowd thinks it means front wheel horsepower. They wisely forego the flywheel, and call it crankshaft horsepower, to avert confusion.
Old Jun 4, 2010 | 05:52 PM
one92rs's Avatar
Car: SOLD!!!!!
i believe that he needs to clarify which vortec heads are going to be used.
Jake_92RS
Jan 28, 2020 10:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
makaveli09
Aug 12, 2015 09:07 PM
89-S-dime
Aug 12, 2015 11:57 AM
