would it be a problem if my car ran too cool
Old Jun 6, 2010 | 11:56 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
this is really just a hypothetical question for the near future. along with my new afr195s and zz409 cam. i am going to get a bigger radiator but currently run anywhere between 165-185. just wondering if running cooler then that would have an aderse effect on my car.
Old Jun 7, 2010 | 01:22 AM
travis401's Avatar
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Re: would it be a problem if my car ran too cool
If youre running fuel injection running too cold will keep the car from going into closed loop mode.
Old Jun 7, 2010 | 02:26 AM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
If your not running a computer I would not see why not. In Chevy Mag. they say running colder = more performance, other people say chevy motors run better hot then colder. I would rather have my motor on the colder side if its got a carb but that just my opinion.
Old Jun 7, 2010 | 02:41 AM
travis401's Avatar
Car: 91 Camaro RS
His stats say 350TPI, so hes running a computer.
Old Jun 7, 2010 | 02:48 AM
travis401's Avatar
Car: 91 Camaro RS
Fuel injected engines like around 180-190. Any colder than 160 in a carbed engine and the fuel will have a harder time atomizing.
Old Jun 7, 2010 | 03:03 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
HOTRODSRJ’s COOLING TIPS
Operating temperature vs power and longevity!
http://www.carnut.com/ramblin/_cool3.html
Old Jun 7, 2010 | 03:19 AM
ymenic's Avatar
Engine: 307
Axle/Gears: stock
180 it is
Old Jun 7, 2010 | 04:36 AM
KnottyBuoyz's Avatar
Car: 87 IROC-Z
Engine: 5.7 TPI
Axle/Gears: Not sure, gotta look it up
Not to mention that a TPI running to cold will get really shitty gas mileage. Don't ask how I know!
Old Jun 7, 2010 | 10:54 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
so 180 it is. also what is the difference betwen closed and open loop
Old Jun 7, 2010 | 11:44 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Are you running factory guages? I'm asking because when I switched from factory guages to all Autometer guages my temp guage showed almost 20 degrees hotter. That was the only change I made at the time. I also trust the Autometer guage more than the old factory guage. I also found my motor runs best between 180 and 190. I am carbed though.
Old Jun 7, 2010 | 04:39 PM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
i am running autometer. i was just wondering though bec i was told the car may run hotter with those heads and cam.
Old Jun 12, 2010 | 09:10 PM
javscamaro's Avatar
Running to cold does Irreversible damage to your engine. Engine parts wear faster and will lead to more problems in the future.
Old Jun 13, 2010 | 12:24 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
how do you figure. i only thought it may in some untuned cases make the car perform like **** bec of the computer
Old Jun 13, 2010 | 02:37 AM
travis401's Avatar
Car: 91 Camaro RS
If you look at post #6, there s link to a test that was performed. It shows that with lower temps comes increased cylinder wall wear.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Leggman1
Aug 6, 2015 04:15 AM
