1989 IROC not running right
Old Jun 19, 2010 | 05:19 PM
ffshrek's Avatar
Hopefully someone can help. I just bought a 1989 IROC with the 5.7l TPI eng in it. Here is my problem: The car idles and runs great until you push the accelerator pedal past 1/3 of the way down, after that the car acts like the fuel is being cut off (like it is in some kind of valet mode or something). I have checked and adjusted the TPS, checked fuel pressure, the fuel pump and filter, distributer cap,plugs and wires have also been changed. Please Help!!!!!
Old Jun 20, 2010 | 01:18 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: 1989 IROC not running right
Hmmm, do the rpm's keep raising even if it's sputtering? Or does it act more like a rev limiter. Does it do it only when hot, only when cold, both?
I'd put money on a faulty MAF, or maybe the previous owner swapped in an SD set-up and it has a MAP.
Does it do it when in park? 1st gear? 2nd? 3rd and 4th? Is it worse going up hills?
Old Jun 20, 2010 | 11:52 AM
ffshrek's Avatar
Thanks for responding, The RPMs go up smoothly unless you romp on it, it does it hot or cold, it has done it in park but not always. It also does it in all gears and no it is not worse going uphill. How do you check the MAF? Ive found voltage readings but dont know what pins to read it on.
Old Jun 20, 2010 | 01:43 PM
ntomsheck's Avatar
Car: 1989 GTA
An SD set-up is the computer system used from '90 to '92. It utilizes a MAP sensor (mounted on the plenum, by the distributor) instead of a MAF sensor. To check a MAF sensor, you need some sort of datalogging program to read the airflow as the car runs. If it goes up/down smoothly, then the MAF is fine. If you don't have this, I can only recommend swapping the MAF for another one. If it doesn't fix the problem, then just return it and get your money back. It definitely sounds like MAF issue considering: the vehicle only does it when it's under load (or mostly only does it when it's under load).
If the MAF doesn't fix anything, I'd check your ign system.
Old Jun 20, 2010 | 10:44 PM
ffshrek's Avatar
Check this out: I unplugged the MAF and it solved the cutout/surging problem but of course did not idle smooth and wanted to die. I purchased a new/remanufacturd MAF and installed it and now it threw a code 33 (MAF sensor, it has not put out this or any code at all prior) and does not idle well but it also does not cut out or surge. I think I may have gotten a faulty MAF. This is frustrating.
Old Jun 21, 2010 | 01:12 AM
ntomsheck's Avatar
Car: 1989 GTA
Yeah, it's not uncommon to have to run through two or three MAF sensors before you get one that works. If you can find a delco, you're set. That, or just buy a cheapo (but working) unit, and read up on MAF to MAP swaps in these message boards.
Old Aug 24, 2012 | 09:20 PM
Fatal213's Avatar
Car: 1989 iroc-z camaro
Engine: 5.7L
Transmission: automatic
Did you guys figure out if replacing the maf sensor solve code 33?
Old Aug 24, 2012 | 10:36 PM
ibmtech's Avatar
Car: 1987 IROC-Z
Engine: TPIS II Supercharged w/Nitrous
Transmission: 700R4 Probuilt
Axle/Gears: 3:73 Richmond 12 Bolt
Have you changed the fuel filter?
Old Sep 3, 2012 | 01:22 PM
Fatal213's Avatar
Engine: 5.7L
I do believe I changed it a couple months back I recently replaced the fuel pump and the filter seemed to be fine I still have code 33 it starts up fine but when i drive down the street it starts acting up its almost as if it wants to shut off
Old Sep 4, 2012 | 11:03 AM
ffshrek's Avatar
It did solve it, also, when trying to troubleshoot the problem, I unplugged the sensor and the car ran smooth, but of course did not have as much power. Hope this helps.
camaro11j
Sep 19, 2018 08:49 AM
Derick15
Members Camaros
Aug 20, 2015 10:19 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
Rustyweb7
Aug 9, 2015 03:05 AM
