Cam change, pushrod lenght
Old Jun 24, 2010 | 08:33 PM
Harwood's Avatar
Car: 1985 Pontiac Firebird
Engine: '93 LT1
Axle/Gears: 4:11
Uh oh. I have no idea what pushrods I need. I've changed to Comp cams K12-771-8 with the roller lifters that came with the kit and my roller rockers. Everything else is currently a stock 400 sbc lower end.
So the question is, how do I solve what lenght pushrods to use? Or does somebody already know the answer to this question.
Thanks a million, crew,
Old Jun 24, 2010 | 09:26 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Cam change, pushrod lenght
For most people, unless you've done drastic changes with high end performance heads, longer valves/springs etc, stock length pushrods will probably work fine. To find out the proper length, you need an adjustable checking pushrod and a lightweight checking valve spring. The Comp Cams web site has information on how to check pushrod length.
Old Jun 25, 2010 | 07:51 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
http://www.circletrack.com/techartic...gth/index.html
beastin91rs
Oct 9, 2015 07:38 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
86White_T/A305
Aug 17, 2015 12:16 AM
