ReBuIlT 350...WaT wEiGhT MoToR oIl Do I uSe???...
Old Jul 2, 2010 | 11:21 PM
83C_CamAroZ28's Avatar
Car: 1983 Z-28
Engine: 5.7 L
ok so i just got my 350 rebuilt......so im wounderin wat weight motor oil do i use?...also would i need to use break in motor oil?...if so how much of that would i need...
any help advice would help...thanks...
Old Jul 2, 2010 | 11:59 PM
cprepared125's Avatar
Car: 85 Z28 scca C Prepared
Engine: 5.7 348 RWHP
Transmission: t5
Axle/Gears: dana 44 3.41
Re: ReBuIlT 350...WaT wEiGhT MoToR oIl Do I uSe???...
I've always used 10w 30 and the cheapest regular oil I could find (Not synthetic) for the first 300-500 miles or so. too slippery of an oil won't allow for proper break in. 5qts should do it unless you have a bigger pan or somethin
Old Jul 3, 2010 | 01:25 AM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Assuming you will be using a non roller cam you should use a break in specific oil or some 15w40 diesel oil.
Old Jul 3, 2010 | 01:41 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
WaT yEaR iS tHe MoToR?
Old Jul 3, 2010 | 08:44 AM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...yea its a non roller...the motor is an 80...ok i was told 2 use break in oil...is this needed?...if so how much break in oil do i use?...the i had the whole engine rebuilt new everything....
Old Jul 3, 2010 | 08:51 AM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
I swear by the Royal Purple break in oil!!! I wouldn't even build a non-roller engine with today's non-zinc oil, but if you have to run a flat tappet cam, make sure you run EOS or similar additive to get some zinc back in the engine or you're gonna waste the cam real quick!!!
Old Jul 3, 2010 | 07:27 PM
Car: 1983 Z-28
Engine: 5.7 L
ok...how much of that would i have to put in it?...do i mix the break in oil with the regular oil?...or do i put all 5 qts of break in oil in it?...help plz...im try to do this right...
Old Jul 3, 2010 | 08:11 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
5 quarts, or whatever your normal oil capacity is, of the break in oil.... I run mine for the initial fire up and 30 minute run or so, do a bit of tuning, then dump it and put in the oil you plan on using... Whatever oil you use both for the break in and forever afterwards make sure you run EOS or similar product to get some zinc in your oil for that non-roller cam!!!!
Old Jul 3, 2010 | 10:39 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks......
Old Jul 4, 2010 | 10:35 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
You can get a Lucas brand zddp additive at the zone or at advanced auto. Good for breaking in, and for use after with every oil change. the rotella stuff doesn't have the zinc it used to have.
Old Jul 5, 2010 | 08:28 AM
Car: 1983 Z-28
Engine: 5.7 L
ok coo...can i use synthetic oil?...
Old Jul 5, 2010 | 08:59 AM
I would use petroleum oil for the break in. After that, use synthetic if that is what is your preference.
Old Jul 5, 2010 | 01:26 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The rings need to seat before you switch to synthetic. Wait til 5-10k miles and switch. You can use break in oil, or you can use regular oil with a break in additive. It's a lot easier to get a holdof a break in additive in my experience. Check out GM's EOS, or Comp Cams' Break In Oil.
Old Jul 5, 2010 | 07:57 PM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks...yes im gona us the break in oil first and then i will b switchin to a different oil......
Old Jul 5, 2010 | 11:45 PM
thedrewdotcom's Avatar
Car: 1986 IROC
ArE yOu A mIdDlEsChOoL gIrL?
Old Aug 23, 2010 | 02:32 PM
Antlocks's Avatar
Car: 82 Z28 .... 74 Nova
Engine: 350 Crossfire Injection....383 Sbc
Transmission: th350 ... 700r4
Axle/Gears: 2:73 Posi ... 3:42 Posi
i have the same problem with my rebuilt 350... i didnt know what type of oil to use to break it in..so im guessing that break in oil from lucas or royal blue should do the trick?? do i add 5qrts of break in?? or 5 reguaar plus 1 of break in?. and run it for about 30 minutes at 2000rpm ?
Old Aug 23, 2010 | 02:42 PM
Was you engine rebuilt with roller lifters?
Old Aug 23, 2010 | 02:48 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
You say that you had the motor rebuilt. If I were you, I would ask that question of the rebuilder. I am assuming that there is a warranty, and therefore you would want to follow their recommendations. They know what they did and if you follow their advice, you won't have any issues if you need warranty service.
Old Aug 24, 2010 | 01:01 AM
Car: 1983 Z-28
Engine: 5.7 L
ok thanks i will surely do that...
Old Aug 24, 2010 | 05:14 PM
Car: 1992 Camaro RS
Im paranoid about my flat tappet cams - I'd use something by one of the big cam manufacturers that actually have to warranty their cams, and will only do so if you use their oil.
I'd suggest using something by Comp, Lunati, Crane, or GM's EOS, etc. What I would do is just fill it up 2 qts, dump the break in oil in the gallon jug, mix it up, dump that in, and throw in the extra quart. It'd be filled a little over capacity but that's not a huge deal. I've seen the Corvette club guys actually reccomend that to keep the oil pump fed in hard cornering.
Old Aug 24, 2010 | 06:29 PM
I did find out from Pennsoil that Rotella has 1200 parts per million of zddp. The who ever he was guy told me that it is enough for flat tappets. I have also heard that zddp plus is a good additive. It can be used with modern SM rated oils to bring the zddp up to safe levels.
Old Sep 14, 2010 | 05:26 PM
Antlocks's Avatar
Thats Exactly What I Did
and im pretty happy with the results
the engine feels strong
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
