battery quickly discharges
Old Jul 4, 2010 | 01:07 PM
blue iroc's Avatar
Car: 1989 iroc
Engine: 5.7 L98 tpi
Transmission: TH700-R4
Axle/Gears: 2.77
Had the battery charged at the local advanced store. The person said that the battery checked out good. I hooked it up to the car and it started just fine but, as soon as I turned it off the car wouldn't start. It just gave out the clicking noise. What would cause the battery to drain so quickly? Hopefully it's just the battery nothing else.
Thank you,
Gerry
P.S. the battery is about 3 years old.
Old Jul 4, 2010 | 02:49 PM
92'STOCKER's Avatar
Car: 92' Z28
Engine: 5.7
Re: battery quickly discharges
Have your battery tested again and see what the charge level is. If the level is good have them check it under load.
If the battery checks out you should start looking at the starter solenoid or the cables.
gta892000
Aug 11, 2019 11:16 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
Johnoooooo
Sep 22, 2015 08:55 AM
sahlomonic
Sep 20, 2015 07:15 PM
gta892000
Sep 16, 2015 12:37 AM
