car stalls
Old Jul 11, 2010 | 07:01 AM
shahi's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Manual
car stalls
i gotta 91 rs tbi stock, manual trans. the problem is that after driving at 80-85 miles/h for like 4 mins or so and i slow down the car turns off. the other day i almost avoided an accident thank god, was going to slam into a divider, but it was manual trans some how managed to turn it on in 2 gear.
well this problem is mostly when im driving in a/c, without a.c some times.
dont know wat to do????????????????????????????
Old Jul 13, 2010 | 04:28 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
Re: car stalls
How is it behaving before it dies? Do the rpms drop rapidly and then try to revive itself and then die? Does it just straight cut out? Sputtering? Depending on what its doing you can track down a cause, but my toilet bowl injection system does the same crap in AZ ill be cruising along and stop at a light and it just kills itself sometimes
Old Jul 13, 2010 | 07:39 AM
shahi's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: car stalls
yes u r spot on, i mean the rpms drop rapidly and then try to revive itself and then dies any solution.....
Old Jul 13, 2010 | 08:36 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: car stalls
to be honest ive never found a solution to it, i just replaced my battery and put in a new starter so when she dies, i can bring her back. Id check the Pigtail connections at the injectors to make sure theyre snug and the rubber boots inside of them havent walked their way off, its definitely a fueling thing though
Old Jul 14, 2010 | 12:23 AM
Tyler Mac's Avatar
Car: 1989 Camaro RS
Engine: 2.8L 173 C.I.
Transmission: 700 R 4
Re: car stalls
my 89 2.8L does this same thing... and usually in a high traffic area. Ive found its easier to just shift into neutral (auto transmission.) and rev it a bit and then when the light goes green, back into drive or overdrive.
Old Jul 14, 2010 | 08:07 PM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: car stalls
ive never found it to be anything but an inconvenience, mine did it at random intervals
Old Jul 15, 2010 | 12:39 AM
shahi's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Re: car stalls
so is this normal, or we dont have any solution for it......
Old Jul 15, 2010 | 02:49 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Re: car stalls
Normal for the car? Originally no, but I've seen almost every tbi do it once or twice and there's no solutions I've found
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
TreDeClaw
Aug 14, 2015 06:58 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
killer777
Aug 8, 2015 02:47 PM
