Best way to change valve springs?
Old Jul 11, 2010 | 11:47 PM
VandykeT/A's Avatar
I've got a 86 Firebird that I just lined my transmission out on and now I'm ready to change my valve springs. Its a LG4 with a XE 268 cam and I've got the valvesprings that match it. What would be the easiest way to change them? Or do I really need to change them?
Old Jul 12, 2010 | 12:00 AM
Doom86's Avatar
Car: '86 Z28, '91 RS
Engine: 305ci, 305ci
Transmission: TH200c (no kidding), TH700r4
Axle/Gears: 2.73, 2.73
Re: Best way to change valve springs?
yes you need to change the springs, lifters and timing chain.
Old Jul 12, 2010 | 12:17 AM
VandykeT/A's Avatar
I all ready replaced the lifters and timing chain. I just wonder what would be the easiest way to change them. Take off the heads, top dead center and use a on car spring compressor or use an air hose. We actually rebuilt the motor but didn't have a valve spring compressor at the time and we rebuilt it outside in the middle of winter so I wanted to get it back together and in the car as quickly as possible. And would it hurt to drive the car with the stock springs for a few days if you take it easy on it ?
Old Jul 12, 2010 | 12:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I don't have a air compressor so I jam 3ft of 1/4" nylon rope in through the spark plug hole and rotate engine around until it locks the valves in place.
No worries about power going off or someone tripping over the air line while you have a spring out
Old Jul 12, 2010 | 07:16 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
gaskets are cheap enough, just pull the heads and use a C clamp style valve spring compressor.
doing them on the engine is no fun.
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
gta90
Sep 15, 2015 04:00 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
