charcoal cannister problems HELP!!!!!!
Old Jul 13, 2010 | 07:16 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
My charcoal cannister is leaking fuel from the bottom, there isnt anything there but a filter looking thing!! HELP IM LOSING FUEL!!!, also if it helps i just put on new fuel lines and put in a new pump!!
Old Jul 13, 2010 | 07:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: charcoal cannister problems HELP!!!!!!
I read your other post on this...
You replaced the ENTIRE fuel line from the tank to the engine with rubber?
If so, bad move - not safe.
If so, did you at least use FUEL INJECTION hose? It states "fuel injection" on the hose - if it does not, it's carb hose, and won't hold up to the pressure of the fuel injection fuel pump. Also, FI hose is about $3 a foot, carb hose about $1 per foot. For the cost of three runs of FI hose from the engine to the tank, you could have more cheaply gotten replacement hardlines (which is what you need anyway for safety issues). No telling what rock, piece of glass, etc will get kicked up and tear the rubber hose causing a gas leak!
Sounds like in the process you've connected the wrong line to the evap canister.
3 fuel lines - the larger one was 3/8 - it's the feed line, two smaller ones each 5/16, one is return line to the tank, one was to canister.
But sounds like your hard lines are now entirely gone?
If so, you're going to have to redrop the tank, figure out which is which, and rerun them correctly to the engine bay.
Old Jul 13, 2010 | 08:03 PM
Engine: L31 350
iv ran lines from the pump to the lines that start at where the pump plugs in on the hump behind the rear seat!, also that sounds right i paid alomst $3 for that line because i got 12 foot, and paid like $40 something, i have four lines though? also the lines on the evap and the return are differance in thickness right? because i have 1 next to the wheel is the sending line, 2. second from the wheel is my return, and 3 is my evap, i did this in the thickness in the hard lines, 1 is the fattest then on down, am i wrong?
Old Jul 13, 2010 | 09:27 PM
Car: 1992 RS
Engine: Carbed 350
the 4th hardline near the tank is the rear brake line.
feed line is largest (3/8)
return line is 5/16 and evap line is 5/16.
evap line should be the longest looking from firewall towards front of car
Old Jul 13, 2010 | 09:29 PM
Engine: L31 350
but how can i tell this from at the tank?, i have all the hardline except from where the old rubber lines use to me to my pump.
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
TBRays98
Sep 6, 2015 05:05 PM
andy74
Sep 3, 2015 08:41 AM
