Seat Pressure and Self-Aligning Rockers
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
Hey guys, I've got a set of Vortecs I'm setting up to use on my 305 (for now) with a ZZ4 cam. My machinist wants to set them up with larger diameter springs in the ~150# seat pressure range and I believe ~310# open. I will for sure be using screw-in studs, but he also told me not to use self-aligning rockers, I currently still have stockers on there, which he said would break under that pressure. He said I need to go the guide plate/non SA rockers.
What are some of your suggestions on valvetrain/rockers? I'd assume I would have to replace my valve covers also if I go with non SA rockers, since mine are centerbolt and meant for narrow arms. Give me some input guys. He was kind of talking me out of putting work/money into stock vortecs with their fairly thin decks.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Seat Pressure and Self-Aligning Rockers
Wow, you sure got suckered. Forget the screw-in studs, keep the self-aligning rockers, and use these springs: http://www.competitionproducts.com/H...uctinfo/98111/
That'll give you good power through 5500 rpm.
Vortec decks are NOT so thin as to negate the value of porting. Here's the info on that: https://www.thirdgen.org/forums/engi...c-heads-2.html
Engine: 305 TBI
Thanks for the reply. I didn't do any work I left with my heads. The screw-in studs were my choice, because the last set of heads I had yanked 4 of the press-ins out. Those springs you suggest look like they're recommended for a mild flat tappet cam, is that enough for a mild/mid roller cam? Competition products doesn't give much detail on their parts I've noticed in the past.
I guess the deck seemed thin, but compared to other OEM heads I've got it seems pretty standard. Thanks for the link, good info there.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
these springs are 90 psi at 1.700", but that's better than the springs that GM puts in the crate ZZ4 engines. These springs will also fit stock retainers, and accept 0.515" lift if installed at 1.700". You do need to check your spring-to-valveseal clearance, and your retainer-to-seal clearance, but otherwise, just pin the stock studs and you're good to go. Keep it to 5800 max.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The springs should be close to what the cam recommends having and the springs should be set up to what the cam recommends. High seat and open pressure springs are only recommended on billet cams. If high spring pressure are used on a cast cam, they will break the cam. High spring pressures will require screw in studs. If you have low spring pressure springs pulling out pressed in studs, you may have other issues.
Like Atilla recommends, springs that are similar to what the ZZ4 cam wants will work fine.
The triple springs on my BBC heads have around 300 pounds seat pressure and around 800 pounds open.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
All GMPP roller-lifter cams are steel-core, not cast-iron-core, AFAIK
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I would definitely say keep an eye on the RPMs. This is for an LT4 hot cam with LT4 springs + vortecs, but I can say from this that they dont seem to like high RPMs too much with the heavy roller lifters and standard valves (LT4 has hollow stem/sodium filled). https://www.thirdgen.org/forums/diy-...eaks-up-3.html
It looks like the ZZ4 uses LT4 valvesprings. Theyre ~100 on the seat, 260 open for reference.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The 100-pound LT4 springs come in the HOT cam kit, not standard on the ZZ4, unless something has changed Very recently.
Car: 88 Camaro SC
Engine: SFI'd 350
The parts list I saw for the ZZ4 showed them with the LT4 springs. But, it could be wrong.
Never the less, I still think they would be a good reference point for spring choice. Unlike a flat tappet, the roller lifters give a little more leeway, so a little extra spring pressure (within reason) would be nice added insurance.
Engine: 305 TBI
Thanks for all the info guys, you've given me a lot to think on and research lately. Lots of good links too.
My thoughts now are Comp 918 springs and I believe 787 retainers. Some other retainers just list valve stems as "stock" so I'm afriad those are for GenIII stuff with 8mm stems. The 787s look like they're set up for GenI 11/32" valves.
My heads are already cut and I have 1.60" exhaust valves. I am going to get all the valves back-cut and possibly a valve job depending on how they check out. My understanding is that the 918 springs with 787 retainers will clear the stock valve guide bosses without machining. I've also seen information in multiple places that these springs set up at 1.800" installed height will give me ~.550" valve lift clearance. So my .510" exhaust lift with the ZZ4 cam should be ok.
Would you guys agree that my information is correct? Also, I will definitely be checking that valve lift is ok once they are set up.
Atilla, that is a very detailed head porting link, great information, thank you. I've read through that thread and I read a David Vizard book about a year ago, so I think I'm going to try my hand at some port work.
Car: 88 Camaro SC
Engine: SFI'd 350
Those retainers will work provided you get the right locks. You might also consider running superlock retainers (747?) and 10 degree super locks. They're stronger and are about the same price. I dont recall what offset you will need to use. Make sure you measure it. You may find that you will need to use offset locks and/or shims to get close to the desired install height.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
How do you propose to get 1.800" installed height? Don't even think of using valves that are 0.100" longer than stock. Those really mess with the valvetrain geometry of stock heads.
I suggest you use "plus fifty" locks, and install the 26915 springs at 1.750". This will be safe with your 0.510" exhaust lift. For what you're doing, the 918s are no advantage over the 915s, just a few dollars price difference.
Also, forget Vizard's advice on grinding away the quench pad by the spark plug. It doesn't hurt anything, and removing it hurts combustion. If you want to use your polishing rolls to round off the edges, that's fine.
Engine: 305 TBI
Thanks Dimented and Atilla, you guys are a lot of help.
I'm figuring out this valvetrain stuff now. So, straight up no shimming, no offsets, a stock valve length will put you at 1.700" installed height? All these beehive springs reference seat pressure at a 1.800" installed height, is that because they were designed for a LS style setup, are LS valves .1" longer than standard SBC valves? This is just for my education here.
Why do you recommend the 915 springs over the 918 springs. I believe the dimensions of them are the same, just different spring pressures. So do you suggest going for a spring that will sufficiently control the action of the valvetrain with the least amount of spring pressure?
Thanks for the tip on the quench pad, I think I may just stick to a little port work and maybe polish the chambers. I have noticed the throat of the exhaust ports looks very small now after its been opened up for a 1.6" exhaust valve.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The length of LS valves is irrelevant, but LS springs do install at 1.80". And these 915s and 918s allow 0.600" at 1.8", so at 1.75", they'll take 0.550".
Over-springing hydraulic lifters causes them to collapse somewhat. Not permanently, but even so, it's to be avoided. That's why AFR invented their Hydra-Rev kit. You don't need it, the ZZ4 cam is done at 5800 rpm.
As to the exhaust throat, I covered that in my porting thread i linked you to. first make sure they did the 75-degree cut pretty close to my spec, If not, get it done. Then do your best to hand-grind a 90 degree angle on the short turn side, then blend that to create a large, gentle, smooth radius.
On the long side, after the bowl hog, there's no need or place for a 90*, so just blend. Post pics of your first one, before trying the other 7.
Car: 88 Camaro SC
Engine: SFI'd 350
I would recommend buying the retainers and locks first to see where your installed height will be.
I also recall my vortecs coming with exhaust valves that had a spun welded hardened valve face that caused the retainer to move down about .050". This also required that the spring seat be lower on the exhaust side than the intake on my factory vortecs. But, the valveguide boss is at the same height as the intake. I seem to recall this limiting the max lift to .480" with the +.050" offset valvelocks. I dont know if this is true for ALL vortec heads. You may want to check it as you may find that you will have to machine the bosses down for standard aftermarket positive seals.
You can check by taking a look at the exhaust valves that came with the heads. If they have the different colored spun welded valve face, then you may need additional machining.
Car: 88 Camaro SC
Engine: SFI'd 350
Also keep in mind that you dont need to hog the ports out. With vortecs, its more of a smoothing and radiusing operation to get a clean, smooth good flowing port. I ported mine, but never got around to trying them.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
But only with that much of it.
Comp lists the 915 as having the same rate as the 918, and both have lower rate than the 26981s. Do the math yourself, you'll see it's true.
What pressure they have on the seat depends on the installed height. I've had 915s to 7000 with hydraulic roller and 2.02" valves, so no problems there.
There's a lot of conflicting info about how much lift stock Vortecs will take, but I've seen them be good for 0.520" out of the box with just a change of springs and locks. So there's been a lot of manufacturing variance.
To cut the guides, the tool that reduces the O,D. is $50, but for $4 less, you can get a tool that does the same job plus cuts the spring seats to accept 1.440" springs, allowing you to run COMP 982-16 springs inverted, saving you over $100 versus running beehives.
Then to cut the guides the other way, for more lift, can be done using a 5/8" bit in any drill. Not ideal, but not a problem.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The cutter is here: http://www.competitionproducts.com/S...ductinfo/4718/
but you also need this: http://www.competitionproducts.com/V...ductinfo/4732/
Car: 88 Camaro SC
Engine: SFI'd 350
I agree that theres a lot of different vortec configurations out there. I know mine actually had an absolute max lift of .450". With the flat tappet I originally had, I was actually the hitting the seals with the retainers.
Car: 88 Camaro SC
Engine: SFI'd 350
As for the 982, I thought of doing that as well since my heads accept a 1.460" spring, but I already had a set of beehives on hand, so I just ran them instead even though theyre smaller than the cups.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
As far as the springs go, its the other way around, the 26918 is the highest of them in terms of spring rate, but yes, I understand what your saying. The 915 installed at 1.750 will give the same relative pressures as the 981's at 1.700, which is why I picked them up for my combo.
Rate is different from open pressure. To determine rate, subtract the seat pressure from the open pressure, call that P. Subtract the open height from the seat height, call that H. P divided by H is rate.
The new 918s have NO place in SBC builds. WAY too much open pressure. they will pull studs out of Vortec heads.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
What cam was that? Im currently converting over to a roller, and am curious myself.
The cam was a custom grind, as are most of the cams I try. That one used COMP's 3112 lobe, a 112 spread, a real ZZ3 block, an L99 crank and rods with ARP bolts, old AFR 190 heads, and an Edelbrock single plane, with 1.75" primaries. I'd be happy to spec you a couple of choices, in a regular thread or by PM.
Engine: 305 TBI
Ok, I actually found similar valve springs, the PAC 1218 beehives, for $120, which also have a 313lb/in spring rate and 130# at 1.800 installed height and 318# at 1.200" open.
So, if I get .05 offset locks and Comp 795 retainers (10 degree parts) and install them at 1.750" I should be at 145.66# seat pressure and about 294# and 305.5# at full lift of the ZZ4 cam on the intake and exhause side respectively.
I measured my valve guides to be 0.8" from the seat to the top of the boss. This, added with the depth of the retainer being ~0.35" would leave a theoretical .60" clearance between bottom of retainer to top of guide boss. With the valve seal added on, I'm assuming I should be fine clearance-wise for my cam and still okay if I set up to a cam with more lift.
I also measured the base of the boss' diameter to be Max (out of 16) 0.855" which should be fine for the inner diameter of any of these springs. The top stepped-in portion of the boss gave me a Max 0.52" diameter.
Obviously this is all theoretical until I get everything put in, but it makes me a little more comfortable to start making some part purchases.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You still don't need 10-degree locks, since you're still under 306 pounds. Otherwise, it all makes good sense.
Engine: 305 TBI
Car: 88 Camaro SC
Engine: SFI'd 350
I wouldnt be surprised if the PAC springs came from the same vendor as teh comp ones. A lot of teh parts now sold by various cam companies all come from the same manufacturers. Those springs are virtually identical in specs to the comps.
I also used the 10 degree locks/retainers as I have several sets of single and dual coil springs that Ive used over the years, some with more open pressure than others. The cost difference isnt huge, so it cant hurt to get something a little extra.
Engine: 305 TBI
ambainb
Apr 25, 2016 09:21 PM
