help: cranks forever then starts..........wtf?
i searched theese fourms forever...........could not find my specific prob so if this thread is multple sorry....
here is the deal....... 87 firebird formula 350 TPI no mods. runs real well so im not messin with it. when i start it hot or cold.........it dont matter how long it sits either. it cranks for three to seven seconds and when it starts it smokes like hell smells like gas big time and sounds like it has a big cam.....then fine......no smoke no miss. fuel pressure/ senors all in workin order. i just dont get it.
help a bow tie out would ya?
thanks fellas
thanks fellas
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 82 Z28
Transmission: T400
Car: 1990 formula firebird T-top
Axle/Gears: thinking 2.73
Re: help: cranks forever then starts..........wtf?
i agree with the idea that it might be the map sensor. should be on the top right of the intake as u are in front of the car... if that is acting up it will dump gas like crazy
also what about your timing. if the distributor is off it would cause it to turn over accesivly and not start at first and be dumping alot of fuel
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
You need a scanner to troubleshoot EFI.
Usually long cranks are not enough fuel, or not enough timing. The fact that it surges and runs rough when it catches, smokes a little, etc had me wondering.
It's unlikely the MAF is the culprit, however you can unplug it and crank and see if it fires. It will ignore MAF input if the sensor is unplugged.
Another chance is a sticky iac, but I'd expect the car to stall at red lights.
-- Joe
-- Joe
-- Joe
-- Joe
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If the engine is throwing codes you dont need a scanner to check them. Just a paperclip.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
skinny z
Oct 5, 2015 06:23 PM
