scrapping sound on startup...
Old Jul 29, 2010 | 02:52 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
i belive last night i noticed that now when starting the camaro there is a metal to metal scrapping sound after its been cranking already for a sec. and then she starts, starting time isnt longer its just there is the scrapping. Anyone got an idea what it could be?
I was thinking starter at first because i didnt shim it and its comming back to bite me in the azz but it sounds like its coming from the rear. Whatever it is do you think im safe with it scrapping or should it be tooken care of right away?
and i tried to make a vid and when shefirst stared it make the sound then i turned the car back off again and tuned back on but this time no sound?? HELP!
Old Jul 29, 2010 | 02:58 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
Re: :( grinding on startup
if you have a grinding you want to fix it asap cause if its your starter then you will either grind teeth off the starter drive gear or worse the flexplate, shimming a starter is not hard, if you dont have shims any auto store should have universal ones and all you do is take the starter down and put them in between where the starter meets the block. do you know where the grinding is coming from?
Old Jul 29, 2010 | 03:03 PM
Engine: 305TPI
Re: scrapping sound on startup...
thanks for the fast responce, i totaly re edited beacause i relize the sound is coming from more like the rear end and its more of a metal to metal scrapping sound.
Old Jul 29, 2010 | 03:24 PM
Engine: 305TPI
sorry you can hear the sound but im almost FOR SURE its coming from the rear and you can tell the second startup was slightly longer.
Old Jul 29, 2010 | 04:35 PM
Engine: 305TPI
HELP!
Old Jul 29, 2010 | 05:12 PM
Engine: 305TPI
let me try this again, it actually sounds a little more like a chirp from the tires, but its defintly not that. but it has a little more metal like clang to it though.
Old Jul 30, 2010 | 11:51 AM
Engine: 305TPI
someone...
Old Jul 30, 2010 | 12:24 PM
'87IROCZOWNER69's Avatar
Car: 1987 IROC-Z and 1988 Iroc-Z
Engine: 5.7 350 V8 and 5.0 305 V8
Transmission: 700R4 Automatic Transmission
Axle/Gears: 3.27 Posi
Does the scrapping sound happen when you crank it and then stop and then right away start cranking again or are you just cranking it once?
Old Jul 31, 2010 | 04:34 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
It's just reverberating to sound like it's from the back no doubt. It would have to be a loose or distorted flexplate/flywheel if you asked me, or a starter that is too close to the ring gear. Nothing in the rear is engaged unless you're starting it in gear with a bypassed neutral safety switch.
Especially the "clang" you describe, it definitely sounds like a flexplate. That could be the whole reason you are having problems with starters and shimming them in the first place also.
Old Jul 31, 2010 | 04:37 PM
Car: 92 RS
Engine: a slow one
I just realized that picture was a video, LOL
That is definitely your starter engaging too close to the ring gear. Put a .040 shim in there ASAP and see what you get!
92projectcamaro
Dec 8, 2015 12:25 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
