cylinder bore cleaning
Old Aug 1, 2010 | 01:17 PM
lunaticinaZ's Avatar
Car: 1991 Black Z28 G92
Engine: 350 for now
Transmission: wc t5
Axle/Gears: factory 3:42
Whats a good and inexpensive way to clean up cylinder walls before installing new piston rings?
Old Aug 1, 2010 | 03:01 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
Re: cylinder bore cleaning
You need to get a cylinder hone. The kind with all the little ***** is the easiest to use.
Old Aug 3, 2010 | 10:30 AM
Engine: 350 for now
Transmission: wc t5
OK, I found a bunch of threads debating which is better a flex hone or the 3 blade kind. but I went to look at prices and seen the different grit flex hones avalable. which grit should i use to clean up a used engine? the cylinder walls actually look like they are in very good shape just have the ring around the top.
Old Aug 3, 2010 | 02:39 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
they make a fancy tool for that top carbon ring [ridge reamer] but most just whip out the pocket knife........
Old Aug 3, 2010 | 05:13 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
What kind of ring is on the top? Carbon or a wear ring?
Im not sure on the grit. Hopefully someone knows.
Old Aug 4, 2010 | 03:47 PM
Engine: 350 for now
Transmission: wc t5
It's carbon ring. I hope someone knows. I work in a shop and nobody out here can tell me either.
Old Aug 4, 2010 | 04:17 PM
86 LT1's Avatar
4" flex hones worked the best quick and easy nice crosshatching,the grit can be anything from 120-320, I use a 120 grit for deglazing an un bored cylinder dont go nuts your just deglazing.About 30 seconds up and down nice and easy dont stay at one spot in cylinder and go to deep so the hone comes out the bottm
Old Aug 4, 2010 | 04:56 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
done told ya once, its called a ridge reamer but most everyone just uses a pocket knife to pick it off, its just carbon build up and will return with time.
Old Aug 4, 2010 | 05:00 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
The ridge that the ridge reamer is used to remove is not carbon. Its a ridge of cast iron at the upper limit of ring travel. The ridge develops because the cylinder bore below is worn by the rings. The severity of this ridge is a gauge in determining whether or not to have cylinders bored. We use a ridge reamer when the ridge is so severe that the piston will not slide past it for removal. It saves having to drive a piston out with a big hammer and drift punch.
The grit selection of ball hones is infinite but I think 380-420 is generally good for cast rings. Chrome moly rings require a finer surface but you may note that most chrome moly ring sets for street strip use include a cast iron second ring. This is intended to aid in ring seating and cylinder conditioning, negating the need for the finer surface.
Old Aug 5, 2010 | 12:46 PM
Engine: 350 for now
Transmission: wc t5
Alright, thanks guys. thats the info I was needing.
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
89-S-dime
Southern California Area
Sep 4, 2015 10:34 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
