Spark plug equivalents
Old Aug 6, 2010 | 05:50 PM
tricky1's Avatar
Car: 1982 Pontiac Trans Am
Engine: Chevy 350 Vortec Roller
Transmission: Turbo 350
Axle/Gears: Moser 4.11
I'm putting together a motor and the heads are some RHS Pro Torker vortecs. The sheet that comes with them recommends using ZEX #82070-8 spark plugs for street/strip use. Does anyone know where I can find a chart that shows what is an equivalent to this plug or can I just run the Autolite 605's like I use in my GM vortecs? The ZEX plugs a bit pricey.
Old Aug 6, 2010 | 06:01 PM
NAASBC355's Avatar
Car: several
Engine: Lots of them
Transmission: also lots of them
Axle/Gears: lots of them
Re: Spark plug equivalents
RS14YC6 STK NO. 13 mid heat range
RS12YC STK NO. 401 colder
RS9YC STK NO. 304 colder still
Racing: (very cold)
S61YC STK NO. 280 mid range racing plug
S59YC STK NO. 685 colder racing plug
S57YC STK NO.671 coldest racing plug
These are all Champion numbers
~Couch
Old Aug 6, 2010 | 06:17 PM
tricky1's Avatar
Thanks. I think that first number you have in that list is the Champion equivalent to the Autolite 605.
Old Aug 6, 2010 | 06:28 PM
NAASBC355's Avatar
Car: several
no 603,604,and 884 in Autolite all cross to that number
~Couch
Old Aug 6, 2010 | 06:31 PM
tricky1's Avatar
Thanks Couch!
Old Aug 6, 2010 | 06:37 PM
NAASBC355's Avatar
Car: several
No problem man
~Couch
Old Aug 7, 2010 | 05:10 PM
tricky1's Avatar
Hey Couch, what's the difference, if any, between a RS14YC6 and a RS14YC plug?
Old Aug 7, 2010 | 07:09 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
http://sparkplugs.com
is a great site to look up plug info, they have a cross reff and an application chart, showing all the vehicles a plug will fit.
Old Aug 7, 2010 | 07:46 PM
tricky1's Avatar
That's a great website but I still want to know the difference, if any, between a RS14YC6 and a RS14YC plug? The RS14YC comes pregapped at .045. I'm wondering what other differences there are since a guy at autozone sold me a set of RS14YC's and he couldn't tell me the difference and I'm curious if they'll work in the 1997 vortec motor I'm running now.
Old Aug 9, 2010 | 11:34 AM
NAASBC355's Avatar
Car: several
YC6 is extended tip, and YC is standard tip. They had fine wire options too if you want but those are all hotter plugs, I wouldn't use them in a performance app. Extednded gap plugs supposedly are more durable in that they don't foul as often, but if your compression ratio is pretty high sometimes you run into piston clearance issues. You should be fine either way.
~Couch
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
64goatman
Sep 9, 2015 01:09 PM
Jlanz55
Sep 9, 2015 09:09 AM
89 formula TPI
Sep 7, 2015 11:06 AM
