went from 1.5 to 1.6 rocker arms
Old Aug 15, 2010 | 06:28 AM
tacman444's Avatar
Car: 1982 Camaro z28
Transmission: turbo 350
Axle/Gears: 12 bolt
with a .520/.520 cam
would the 1.6 increase the cam lift ??
Old Aug 15, 2010 | 01:56 PM
DoubleV's Avatar
Re: went from 1.5 to 1.6 rocker arms
Of course it will. Increasing the lift is the whole point of higher rocker arm ratio's. Multiply your cam lift by the rocker arm ratio to get your total valve lift.
The question you need to ask yourself is will it make any difference in your specific application?
Old Aug 16, 2010 | 01:26 AM
meth64's Avatar
Can the springs handle it is another question.
Old Aug 16, 2010 | 06:20 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
You'l pick up roughly.033" lift. As for the springs, what heads are you running, if they are stock I doubt it, hard to say w/o knowing what you are running...
Old Aug 16, 2010 | 07:08 AM
tacman444's Avatar
Axle/Gears: 12 bolt
comp cam springs,
camel hump heads-plained,ported,polished,bigger valves
Old Aug 16, 2010 | 07:25 AM
skinny z's Avatar
Have you run this engine with the new rockers?
Old Aug 16, 2010 | 07:31 AM
tacman444's Avatar
Axle/Gears: 12 bolt
yes i have and also checked valve to piston clearances and there is .100's
Old Aug 16, 2010 | 07:36 AM
skinny z's Avatar
I was more concerned with potential coil bind and retainer to guide boss interference.
The 1.6 rockers have increased the lift from your previous .520" to .555".
That's getting up there.
Old Aug 16, 2010 | 07:44 AM
tacman444's Avatar
Axle/Gears: 12 bolt
yes i was concerned also untill i talked to my machine shop("pro stock" stock car racer, and the person who sold me the valve train (9.00 second racer"owner of the racing shop") ...the only problem i am having now is its street-ability, i/e setting at the stop lights .i cant get a decent idle
Old Aug 16, 2010 | 09:16 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
The addition of 1.6 rockers will not have any affect on idle quality you have another problem.
Retainer to guide boss interference generally occurs at .600+ lift unless you have VORTEC heads.always good to check
Old Aug 16, 2010 | 09:43 AM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
Sounds like the rockers are not adjusted properly.
Old Aug 16, 2010 | 03:47 PM
J91's Avatar
J91
It's gonna lope hard w/ that kind of lift, are you running a stall speed convertor? If not it won't idle at a stop in gear. w/ that cam you probably need to be in the 2800-3200 rpm stall speed range...
Old Aug 16, 2010 | 03:51 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
That sounds more like piston-to-valve clearance. Retainer to valve stem seal is usually more like .475" or so on an unmodified head, IIRC.
I wouldn't expect a cam with .555" lift to idle all that well.
Old Aug 16, 2010 | 06:50 PM
Car: '88 Trans Am
Engine: 5.7L TPI
My machinist showed me that retainer to guide boss has to be machined or the guide seal will get beat to death over .600 so you could either machine the boss or purchase valve locks that provide .050 clearence..
I see where you are headed though.
valve lift has very little affect on idle, duration,overlap etc. play more of a role in idle...
Old Aug 16, 2010 | 07:16 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
True, but that thing's likely to have a healthy duration to go with the lift.
Old Aug 16, 2010 | 07:50 PM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
I'd bet it needs more timing advance...especially if it has low compression (9.5:1 or less), tight LSA and lots of duration. Shoot for 50* or more at idle and slow speed. But, if it was really good before and now it is really bad...try adjusting the valves again.
Old Aug 16, 2010 | 08:05 PM
J91's Avatar
J91
Yes, but you don't get that kind of lift w/o some big duration numbers...
The question is the converter, I run 583/583 lift, if I did not have a stalled converter it would barely be able to idle in gear. W/ my convertor I can idle @ 650-700 rpm all day long
Old Aug 17, 2010 | 07:22 AM
GICATA's Avatar
We're using 1.6 rockers here, increasing the lift without creating the problems long duration does. My little 224 degree cam pushes the valves .500 with 1.6 arms, without a stall converter or idle issues.
Old Aug 17, 2010 | 08:20 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
The cam I'm running now is a solid roller at 236 @50 with .550 lift on a 110 LSA. This is on a motor with close to 11:1 compression and 8.5:1 DCR and it still likes about 15 degrees initial. My old cam (way to much cam) was a 246 @50 with .510 lift, hydraulic flat tappit, and wouldnt idle with less than 18 degrees initial timing. This is with vacuum advance disconnceted. If I had less than that, you could watch the headers glow within 10 minutes of turning the motor on as the fuel was still burning while going in the exhaust. The motor also had no power.
Old Aug 17, 2010 | 08:37 AM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
(It's gonna lope hard w/ that kind of lift, are you running a stall speed convertor? If not it won't idle at a stop in gear. w/ that cam you probably need to be in the 2800-3200 rpm stall speed range...)
Lift has nothing to do with how a cam is going to "lope" thats is based off of centerline and duration
Old Aug 17, 2010 | 09:25 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Your 224 is a weenie .468 or so before the 1.5s are on it. He's already over .520 with the 1.5s, that's going to come with some duration. It's a pretty big cam however you measure it. Look at the Lunati 30121, .520/.520 and 240/240 @ .050.
I'd try it with at least 3000 RPM stall, lock the centrifugal at 34 degrees, and then give it as much non-ported vacuum advance as it wants.
Old Aug 17, 2010 | 10:30 AM
GICATA's Avatar
Your 224 is a weenie ...
I know.
Old Aug 18, 2010 | 09:44 AM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
How 'bout a 214/214 @ .050 .603"/.586" That's weenieER.
Jake
Old Aug 18, 2010 | 09:47 AM
JakeJr's Avatar
Axle/Gears: 3.07
Technically, NO, Not CAM lift; not even Lobe Lift; but instead VALVE LIFT. Gotta keep all these names straight.
Jake
Old Aug 18, 2010 | 09:50 AM
JakeJr's Avatar
Axle/Gears: 3.07
Lifter preload. It's a vocabulary thing.
Jake
Old Aug 18, 2010 | 09:52 AM
JakeJr's Avatar
Axle/Gears: 3.07
True. Minimal.
Jake
Old Aug 18, 2010 | 09:56 AM
JakeJr's Avatar
Axle/Gears: 3.07
214/214@ .050" .603"/.586" High lift - short duration.
Jake
Old Aug 18, 2010 | 11:10 AM
J91's Avatar
J91
Yeah no kidding, but w/ that kind of lift comes more duration, it's a given.... This ain't my first rodeo pal!
Old Aug 20, 2010 | 06:48 AM
GICATA's Avatar
Jake
Mmm, yeah, I see what you mean.
The rocker nuts adjust the lifter preload. The pushrod length adjusts the rocker position. Cam lift pushes the lifter/pushrod/rocker. The rocker ratio effects the valve travel.
We CAN have relatively short duration and still acheive high lift by grinding a fast opening ramp with a tall nose/high lift and manipulating the rocker ratio. Good springs and a gentle closing ramp are necessary at this point. The roller trend has taken advantage of this theory.
Old Aug 20, 2010 | 02:48 PM
JakeJr's Avatar
Axle/Gears: 3.07
One of the major benefits of recent (within the past several years) testing done by the major cam companies is they have been able to create camshaft lobes which result in higher valve lift while, at the same time, keeping the duration on the short(er) side.
They increased, what we usually refer to as the aggressiveness of the cam's lobes. The trick is to open the valve as quickly as possible, accelerate it quickly but not so fast as to cause the lifter to fly off the lobe at max lift - only to come crashing down on the closing side of the lobe. It's a fine balancing act, to be able to achieve that without going too far but the Big Boys have nailed it.
Comp's been doing it for a while with their XE and XFI lobes and Lunati is now offering lobes of a very similar design. Of course, the entire valve train has to be up to snuff to be able to repeatedly handle those lobes and, according to Comp, stock valve train parts won't cut it.
So although long(ish) durations use to always accompany high valve lift cams, the most recent cam offerings have taken a big bite out of that requirement. Of course, one can always pump up the valve lift by making changes in the rocker arm ratio.
Running Comp's MOST aggressive lobes calls for either more spring or lowering the max RPMs.
Hope this helps.
Jake
Old Jan 15, 2013 | 09:19 PM
bigcountry512's Avatar
what is the compression you might have over cam it sound like you need at least a 10.5 to 1 to run that cam
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
