LTI and World Products Sportsman II
Old Sep 12, 2010 | 04:35 PM
Mungo's Avatar
Car: 1989 Iroc Drag Car
Engine: Corvette 350 w/ 2.02 Valves
Transmission: 700R4 Full Manual Shift
Axle/Gears: 410 Richmond
I have a 1989 IROC Drag car that has a 1989 350 Vette Motor. How can I tell if it is an LT1. I have a chance to pick up two World Products Sportsman II heads for a song, but Summit's Website said they will not work on the LT1. My block has an OEM roller Cam Shaft. What I need to know is whether the Heads will fit my block. This is not a computer controlled vehicle. Drag Race only. Running an Edlebrock 750 Carb with Mallory Ignition.
Old Sep 12, 2010 | 05:33 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
Re: LTI and World Products Sportsman II
we will need your numbers on the back of your block. on the drivers side. other than that i think, don't yell at me if i am wrong but lt1's have a cam driven water pump?
Old Sep 12, 2010 | 06:37 PM
Mungo's Avatar
I will have to go to the shop and get the numbers. I have an electric water pump. I just don't want to have any surprizes if I get these heads. The car is far from stock. I guess what I need to know, other than the roller cam, is there a difference in the block from a block prior to 1986?
Old Sep 13, 2010 | 02:11 AM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Look for the thermostat housing. If its on the intake manifold, its a regular small block. If its on the waterpump, its an LT1.
Old Sep 13, 2010 | 08:47 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Get the heads, but don't think of using them. Instead, re-sell them at a profit. They are bar none the worst 200 cc SBC heads on the planet.
Old Sep 13, 2010 | 01:48 PM
Air_Adam's Avatar
They aren't that bad. They are just a dated design, thats all. They are good heads, I liked the set I had. For what they cost, especially for a good used set, they are a very good head.
Old Sep 13, 2010 | 02:25 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Yes, they really are that bad, and worse. Ever checked the short turns? Heck, go look at COMP cams dyno results. Flat or roller. The torque loss when switching from even lame S/R Torquers is dramatic.
Nothing you can build with these heads can even equal the same combo with ANY other 180 cc head.
These heads are for people who are uninformed, or fools, or both. Wise enthusiasts will keep these off their engines.
Old Sep 13, 2010 | 07:46 PM
Mungo's Avatar
Thank you everyone for your input. I have the block number 14093638. Also the thermostat is in the intake. Regardless of whether you may like or dislike these heads, they have to be better than the stock GM heads I have already. I am going to purchase the two for the $100.00
Old Sep 13, 2010 | 09:20 PM
Air_Adam's Avatar
Mine were ported before I got them, so I guess I can't really say what a stock set is like. How much they were ported, I can't say. I liked mine though.
Old Sep 13, 2010 | 10:24 PM
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
you don't have a lt1
this site will tell you what you have.
http://www.chevy-camaro.com/chevy-ca...es.asp?group=1
Linson
Oct 24, 2025 02:00 PM
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
paul_huryk
Oct 1, 2015 04:27 PM
Dragonsys
Sep 25, 2015 03:51 PM
