fuel pressure test for TPI
Old Sep 16, 2010 | 02:02 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
to check the fuel pressure in a TPI engine, you just need to disconnect the line running to the fuel rail,and connect the gauge in place don't you?
Old Sep 16, 2010 | 02:06 PM
InjectorsPlus's Avatar
Former Sponsor
Re: fuel pressure test for TPI
No, there is a schrader vavle on the fuel rail. See pic, it's on the top.right in this picture.
Old Sep 16, 2010 | 02:12 PM
ok, yeah I just went out to my car and found it, its on the passenger side near the back, thanks for the quick reply
Old Mar 30, 2014 | 11:56 AM
captainchadl's Avatar
Car: 1987 IROC - Z
Engine: 5.0 TPI
does the fuel go to the regulated first or to the fuel rail?
Old Jun 11, 2014 | 02:26 PM
wow this is old, the fuel enters the rail first. The regulator is used to create a restriction at the return side of the rail and this makes sure that there is adequate fuel pressure throughout the entire rail
Old Nov 12, 2016 | 08:30 PM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
This might help:
Old Nov 13, 2016 | 12:10 AM
Ricky16's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 TPI
Originally Posted by JRobling
I have simialar symptoms on my 91 tpi 5.0, its struggles to start like yours then eventually after about 3 tries it turn on but it has a rough idle and wants to bog out, as soon as i step on the gas pedal it shuts off. I also think its my fuel pump which ima change next weekend hopefully it gets my car on the road. Thanks for posting the video
Old Nov 15, 2016 | 02:10 AM
JRobling's Avatar
Car: 1989 IROC-Z
Engine: 5.7L V8
I have videos on the fuel pump and the filter.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
