How To Seal Engine During Teardown?
Old Sep 17, 2010 | 08:51 AM
FireDemonSiC's Avatar
Car: 1985 Z28
Engine: 334 Stroker Superram 222/230
Transmission: Full Manual 700R4 / 3k Street Edge
Axle/Gears: 3.90 Eaton, Moser, Richmond & More
In a few weeks, I'm going to be tearing the intake on my LB9 to bolt up my lingenfelter manifold. Since this car is now my project car and no longer my DD, I don't have to worry about time constraints. It will take me a week or two in between the rest of my schedule to port match everything to each other. Since I don't have a garage to keep the car in I obviously don't want to leave the lifter valley exposed for this long so what I plan is to remove the plenum, runners, distributor and fuel system, basically everything except for the manifold base to keep the lifter valley sealed. During this time I will be performing port matching and polishing, and have a few fuel system components I would like to give a facelift to.
When everything is done I will swap the manifold base out within a single day, but in the meantime my question is what is the proper way to seal off the exposed distributor hole/intake ports? Paper towel and duct tape (Yeeeeah that sounds reeeeeeal ghetto fabulous which is why I'm asking)?
Also, do you guys think I will see an imporvement from the upgraded manifold? I know the heads will still be holding her back, but I should notice something right?
Old Sep 17, 2010 | 11:42 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: How To Seal Engine During Teardown?
I'd get a big black garbage bag, and tape it in place. This will keep the water away. I'd make sure everything is still oiled (ie, don't scrub anything with brake-kleen then leave it exposed to the elements for a few weeks eh?)
Old Sep 17, 2010 | 09:55 PM
Guest
Guest
Posts: n/a
Which Lingenfelter manifold? There are at least 3 different choices.
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
formula_novice
Aug 18, 2015 08:48 PM
86White_T/A305
Aug 17, 2015 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Exxon Limited
Aug 9, 2015 08:13 PM
