motor turns but wont fire
Old Sep 20, 2010 | 08:43 PM
pouliot89's Avatar
Car: 89 camaro rs
Engine: 383 stroker
Transmission: 5 speed manual
Axle/Gears: not sure
i have a 89 camaro with an unorigional 383 stroker. it drove fine the other day til it overheated cuz the thermostat stuck. i changed the thermostat and fired right up. the next day i went to start it and it sounds like it wants to start but doesnt fire. i changed a few of the plugs i could get at at the time. still just turns. any ideas?
Old Sep 21, 2010 | 06:40 AM
kd5icr's Avatar
Car: 1985 Camaro Z28
Engine: 305 mild build up
Axle/Gears: Stock
Re: motor turns but wont fire
Does it have fire out of the cap? How about fuel? without either it will never start. Always go back and check the basic things first before going crazy.
Old Sep 21, 2010 | 09:43 AM
pouliot89's Avatar
Car: 89 camaro rs
Engine: 383 stroker
ill check the distributor. what should i look for when i take off the cover to know if its good or not? i was going to, but im just afraid of messing up the wires and not putting them back in the right spots
Old Sep 21, 2010 | 12:22 PM
kd5icr's Avatar
Axle/Gears: Stock
Double check that the power wire is hooked up to the distributor. I assume this is an HEI dist. some times if it has been messed with a bunch it can come off the terminal, so go and check it. If it is ok, Then this:
You dont need to pull the cap off. Just 1 wire from the cap then hold it with something that will keep you from getting shocked next to the terminal you pulled it off of. Have somebody crank the engine over, if you have a spark the we know it is getting fire to the plugs.If not the we move to the next step.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 19, 2015 10:07 PM
86White_T/A305
Aug 17, 2015 12:16 AM
djmarch
Aug 9, 2015 05:27 PM
