Need some help identifiying a cam
Old Sep 21, 2010 | 12:59 PM
Saintanger1981's Avatar
Car: 1992 RS
Engine: 350, Trick Flow Twisted wedge heads
Axle/Gears: 3.45 9 bolt coming soon
I ran the numbers on the block and it is a zz4 crate engine, not too sure if the cam is the one that came with it or not. the only numbers i can find on the cam are as follows:
1264
2 02
7192
f 5
Ive searched high and low and cant find anything about it. Any help is appreciated. I can get a pic up later probably if someone thinks itll help
Old Sep 21, 2010 | 01:22 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Need some help identifiying a cam
Your best place to start is to either reverse-degree the cam, or set up ad dial indicator to determine the lift. Lobe lift times 1.5 equals advertised lift. the ZZ4 cam specs as 0.474/0.510" valve lift, 208/221 duration at 0.050", 112 degree lobe separation angle, 109 degree intake center line with a new, not-stretched chain, and that puts the intake opening at 5 degrees after top center, at 0.050" lobe lift. The intake closing then becomes 33 degrees after bottom center.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
