sticking throttle
Old Sep 24, 2010 | 10:21 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
sticking throttle
ok, getting closer to figuring this out. I have a 91' 350tpi/700r4 bird. After i get on it hard, my throttle feels like it is sticking. This also happens after i go on a long drive (60 miles or so). Somehow from heat? About a year ago i had to put a return spring on my throttle body ( for the car to shift at all)!!!! but it is fine until after i drive it hard and then it needs to cool down. Anyway the car shifts really late. After i let the car cool down or sit for a while , the problem goes away. I also feel my gas pedal coming up from the floor real slow (have to let up on the gas to shift this car remember). So, is the problem a bad throttle body or a bad tv cable? OR, the linkage on the transmission that my tv cable hooks up to?
Old Sep 24, 2010 | 10:23 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: sticking throttle
Oh and WOT shifts are always fine. It is only normal driving previous to a WOT run that is shifts bad.
Old Sep 24, 2010 | 10:27 PM
ls1fiend's Avatar
Car: 1985 z28, 1994 Sierra
Engine: 350, 350
Transmission: T-5, 4L60E
I don't know if this is even relevant to your case but when I changed out my plug wires I had one that laid across the throttle cable before it went in the plastic jacket and it caused my throttle to stick.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
DiabloWS6
20
Dec 11, 2015 04:12 PM
Scorched1984
Sep 15, 2015 03:42 PM
banksGTA
Sep 13, 2015 11:56 AM
Randomtask2
Sep 7, 2015 05:06 PM
