Feel like guessing HP?
Old Sep 25, 2010 | 11:40 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Anybody bored and Feel like guessing my Horsepower?
I have 350 Small Block Chevy Bored .30 over,
Edlebrock Performer EPS Aluminum Intake,
Headers,
Edlebrock 600cfm carb,
GM -462624 Heads (76cc) with Port Job,
Comp Cams Roller Rockers with 1.52 lift,
280-H Comp Cam (Lift: .480'',Duration: 280°, RPM Range: 2000-6000)
Old Sep 27, 2010 | 12:01 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
About 300-325. The heads are seriously holding you back.
The intake and cam are also mismatched.
What headers? What is the exhaust behind the headers?
Old Sep 27, 2010 | 02:34 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Re: Feel like guessing HP?
Everything mentioned came with the car so I didnt do any picking.
After looking up the heads I figured they were junk and crack prone.
Not sure on the headers and exhaust,but I do plan on replacing it with Heddman shorty headers and Y pipe.
Can you explain why the intake and cam are mismatched so In the future I know how to choose the right parts?
IYO,how much should I gain with a good set of heads?
Old Sep 28, 2010 | 08:28 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
bump
Old Sep 28, 2010 | 10:43 PM
lowridetractor's Avatar
Car: 89 Iroc-Z
Engine: 350/carb
Transmission: th350
the eps intake has a makes power from idle-5500 rpms
and the 280h cam makes power for 2000-6000
Old Sep 29, 2010 | 04:34 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
So would a 1,500-6,500 intake match with the cam or a Idle-6,000 intake be a better choice?
Would there be a noticeable power difference to justify spending the money?
Old Sep 29, 2010 | 06:30 PM
five7kid's Avatar
An Edelbrock Performer RPM would work well with that cam.
That Idle-6000 intake is basically the same thing you have now. Their "Stage 2" intake is basically a copy of the RPM. The "Stage 3" is a copy of the Air Gap RPM.
Old Sep 29, 2010 | 07:06 PM
jprix's Avatar
Car: 85 Trans AM
Engine: Chevy 355
Five7kid, how much would you say I should gain with a good set of heads and would there be a noticeable power difference in swapping intakes to justify spending the money?
db057
Jan 10, 2020 08:55 PM
xbazzarex
Exterior Parts for Sale
16
Oct 6, 2015 08:42 PM
85 Jimmy
Sep 30, 2015 07:56 AM
HikoriYami
Sep 21, 2015 07:11 PM
ULTM8Z
Sep 16, 2015 09:15 AM
