can someone tell me what this is?
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
Car: 91 camaroRS
Engine: 350 vortec
Transmission: 700r
what is this hole?
Ok i have gm motor 12530282 & there is a hole between the balancer and timing cover. it looks like something is supposed to plug in there but i dont know what!...please help not much time before the snow comes and i gotta put her up! /Users/ronald/Downloads/24402303944_ORIG.jpeg
Transmission: 4L80E/4L80E
What engine is that?
I'm guessing it's for a timing probe for the dealer diagnostic machine.
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: can someone tell me what this is?
I beleive that is where the camshaft position sensor goes. As Five 7 said, what engine is this?
Car: 87 IROC Z28
Engine: 355 cid TPI
On second thought, this may be a view from the bottom. It think this may be a Vortec motor. In which case that would be where the crank sensor goes.
Assuming the OP's two threads were referencing the same engine, I merged them.
So, sounds like a Vortec engine, and therefore, assuming Doc knows what he's talking about, it's for the crank sensor. If you aren't using a Vortec control system on the engine, you don't need the sensor (assuming I know what I'm talking about - which may not be a good assumption).
+1 on the vortec engine, or atleast the plastic timing cover. You can see the 4x reluctor in there too. If plugging the hole is your only concern, grab a sensor from any of the 4.3/5.0/5.7 vortecs in a JY
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
Crank position sensor hole on Late model Vortec Engine.
