Interesting Oil Pressure
Old Oct 18, 2010 | 03:46 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Something that I have noticed with my new motor is that when I shut it off I can watch the oil pressure gage slowly come down to zero. Maybe it takes 5 seconds for it to reach zero from around 45 pounds at idle. I have never noticed this on any of my other motors. By the way I have the new Dart SHP block with priority main oiling if that might matter. The motor was broken in on and engine dyno and was taken up to 6800 rpm under load so I know the oiling is just fine.
Old Oct 18, 2010 | 08:58 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Interesting Oil Pressure
i can only assume that you have a direct reading oil press. gauge . if so i don't see any problem . good luck .
Old Oct 18, 2010 | 10:11 PM
Car: 1989 GTA
Engine: 369 TPI
Factory gage and sending unit. I agree in I don't see a problem it is only I have never seen that in a motor before.
Old Oct 18, 2010 | 10:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Power to the sender is off when you turn the key off, so it's not reading oil pressure. You're just seeing the gauge drift to a rest position.
Old Oct 18, 2010 | 10:57 PM
Car: 1989 GTA
Engine: 369 TPI
Could well be, I just never noticed it before.
Old Oct 18, 2010 | 11:23 PM
Guest
Guest
Posts: n/a
I've never noticed that happening, maybe I have just not looked.
So... got a date with a dyno soon?
Old Oct 19, 2010 | 01:15 PM
Car: 1989 GTA
Engine: 369 TPI
Dyno looks like some time in November. We have a number of cars ready to go so it might take two Saturdays.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
