Intake valve deposit removal
What's the best product for removing the deposits on the intake valves?
I've tried soaking in laquer thinner and used an aerosol carb cleaner with little effect.
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
Re: Intake valve deposit removal
I've tried all kinds of solvents with little to no luck. I have tried mineral spirits, lacquer thinner, xylene, toluene, r7k54 reducer, carb cleaner, brake cleaner, and vinegar. I finally ended up using a glass bead blaster to get them back.
I've soaked mine in laquer thinner and it would make the deposits soft but not really dissolve them.
I'm cautiously using the wire wheel on my bench grinder to clean them up. So far the results are pretty good. Haven't touched a valve seat yet.
I using a round fibre brush dipped in laquer thinner in my drill to clean up the chambers. Seems effective. I don't believe the fibre brush will cause any damage to the seats. Doesn't appear to anyway.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
No, that's why the beads are glass.
If you're worried about it though, just lap them when you're finished.
Car: 1986 Firebird Trans Am
Engine: Chevy 355
Transmission: Built 700R4
Axle/Gears: 9 bolt 2.77
Just get them pretty clean and Seafoooooam.
GM used to make this product that was such a powerful carbon deposit cleaner it would strip all the oil off the insides and you could ruin your engine. It was discontinued (obviously).
Or do you have a lot of hard deposits?
Car: 92 Jamaican Yellow Firebird
Engine: 305 TBI
I think the machine shop method works best. That method involves me letting the machine shop clean them up when they cut the new seats. Works great and clean as a whistle!
1992rs/ss
Jan 31, 2025 05:10 PM
ambainb
Apr 25, 2016 09:21 PM
