keys?
Old Nov 3, 2010 | 07:52 PM
ducefour24's Avatar
Car: 1992 RS
Engine: 3.1L MPI V6
keys?
okay so i lost my keys and i have no spare. i have a 92rs and i dont know what to do. about 10 years ago my car was broken into and i had to have the ignition cylinder replaced. Now i was wondering if i put in a new ignition cylinder in with the template key it comes with and the bypass the vats will it start...or am i going to have to pay a locksmith to come out and fix it
and help will be greatly appreciated
Old Nov 3, 2010 | 08:15 PM
DukeofHurl's Avatar
Car: 1986 Z28
Engine: 350 Q-Jet
Re: keys?
I think there was a thread in this forum just a couple weeks ago about this, wouldn't hurt to search. But since you had the ignition replaced your VIN would be of no use to the dealer to get you a new set, locksmith might be your easiest answer.
Old Nov 4, 2010 | 10:53 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Re: keys?
Are you saying you already have the VATS bypassed? If so, it really makes no difference what you do with the cylinder. Since you probably already have an aftermarket cylinder at this point, it may be most practicle for you to just remove the steering wheel and replace the cylinder yourself.
Old Nov 4, 2010 | 01:08 PM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Re: keys?
I learned what my key code was when I got it and it saved me some trouble when I had ignition problems. Everyone who owns a car with Vats should have the key number associated to the resistance. Then the replacement ignition wont be a problem. If you do keep the Vats and get it working, take note of it and record it for future issues that may arise.
Old Nov 4, 2010 | 05:33 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: keys?
Originally Posted by TA-Rocks
Everyone who owns a car with Vats should have the key number associated to the resistance...
NO - everyone with a VATS car should have a spare, or three!
But - if you get the right resistors, and bypass the VATS, then any ignition cylinder will work.
BUT ALSO - if you know the resistor value, then you can just have a key made from that old key template with that resistor.
Or, you can get another VATS key cylinder and have the new keys cut with the correct resistor value.
ACE Hardware can make the VATS keys much cheaper than the dealer.
3rd gen money
Oct 11, 2019 09:57 PM
RS Reaper
Oct 17, 2018 07:52 PM
Gunner242
Dec 25, 2015 04:49 PM
Linson
Oct 1, 2015 09:50 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
