5.7 cracked piston
Old Nov 10, 2010 | 08:16 PM
dvardaman85's Avatar
Car: 1985 Chevy Camaro
Axle/Gears: 3.08
5.7 cracked piston
so building a 305 is a joke right? i found a 350 with 1 cracked piston other than that it looks pretty good. supposedly it ran recently. i mean pistons dont just crack right?
should i stray from this?
could the crank be trusted for another block?
so many questions any advice on the matter?
he only wants 150 bones for it.
Old Nov 10, 2010 | 09:03 PM
Guest
Guest
Posts: n/a
Re: 5.7 cracked piston
Not without a reason they dont, unless the part had a flaw and thats generally not likely. Where's it cracked?
Old Nov 10, 2010 | 10:04 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
If the bore isnt damaged (cracked, broken, etc) I'd use the block and rebuild it.... if it's a 1 pc RMS roller block.
I wouldnt just replace the piston and drive it, though.
Old Dec 4, 2010 | 02:08 PM
Axle/Gears: 3.08
well the broken piece is actually like a chunk straight off the top of the piston. you know looking down into the cylinder its off hte top of the piston you cant even see the crank or rod below it.
that being said is it actually a waste of money to rebuild this 350 should i stroke it? i mean for the difference in power and price has it been proven well worth the money just to stroke it?
and how on a bare block could i tell if it is 1 piece or two piece rear main seal
thanks alot for the help
Old Dec 4, 2010 | 02:53 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Was it a fuel injected motor?
Sounds to me like somebody's Air/fuel ratio was way out of whack and fell victim to detonation. If the cylinder walls aren't scored (which I'd bet they are) I'd leave it stock bore. If you run your fingernail up and down the cylinder walls and it gets hung up anywhere, chances are good its garbage.
Old Dec 4, 2010 | 03:21 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It depends how many parts you're replacing. If you need a new crank and pistons, then the material cost is the same.
Look at the rear main seal area.
Old Dec 25, 2010 | 07:04 PM
Axle/Gears: 3.08
well i got a different 5.7 block for free so i am hoping that yall can help me out and tell me 2 or 4 bolt and 1 or 2 piece rear main seal
sorry about my ignorance but im trying to learn
Attached Thumbnails 5.7 cracked piston-enigine-new-1.jpg   5.7 cracked piston-engine-new-2.jpg   5.7 cracked piston-engine-new-3.jpg
Old Dec 25, 2010 | 07:12 PM
Axle/Gears: 3.08
also
Attached Thumbnails 5.7 cracked piston-engine-new-4.jpg   5.7 cracked piston-engine-new-5.jpg   5.7 cracked piston-engine-new-6.jpg
Old Dec 25, 2010 | 07:43 PM
KnightmareCS's Avatar
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
can you get us the casting code? it's on the top driver's side where the transmission connects. that'll help.
Old Dec 25, 2010 | 09:17 PM
Damon's Avatar
That's an earlier 2 piece RMS block. The wide groove just inside the rear edge of the rear main is where the 2 halves of the rear main seal sit.
Old Dec 26, 2010 | 05:15 AM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
On the upside it IS a 4bolt
Old Dec 26, 2010 | 09:04 AM
Twin_Turbo's Avatar
a chunk off the top, a broken ring land is usually the result of detonation.
Old Dec 26, 2010 | 12:08 PM
Tobias05's Avatar
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
Lol, no he needs to get one of those 6 bolt main blocks!
Old Dec 26, 2010 | 12:25 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
nah he should stay away from those
They belong in pickup trucks and fourth gens.
Old Dec 26, 2010 | 04:44 PM
Grumbles's Avatar
I see what you did there
Old Dec 29, 2010 | 08:33 PM
Axle/Gears: 3.08
ok so two piece rear main. thank you and yes i can get cast numbers.
Old Dec 30, 2010 | 01:59 PM
Tobias05's Avatar
So is it going to be faster than the impala, this second time around?
Old Jan 10, 2011 | 07:18 PM
Axle/Gears: 3.08
i dont know what the impala runs to be straight... so i hope so
blackz281le
Jan 11, 2016 07:51 AM
86z89iroc
Oct 5, 2015 01:04 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
