1988 trans am gta tpi 383 stroker horsepower esitmate
Old Nov 11, 2010 | 09:22 AM
nutzar4's Avatar
Car: 1988 Pontiac Trans-Am GTA
Engine: 383 stroker tpi
Transmission: 700r4 Transgo full shift kit
Axle/Gears: 2.73* Posi
I have a 1988 trans am gta with alot of mods i was wondering how much horsepower i should make.
It has a 350 in it with a stroker kit(eagle crank and black jack pistons)
competition cams valvtrain kit(cam 1800-6000 rps, valve springs, lifters, timing chain and gears, ect.)
transgo full shift kit
E3 spark plugs
iron heads with oversized valves
it is tpi with 36# injecters, large intake runners, adjustable fuel pressure regulater(35-75psi)
hedman headers with D shaped exhaust ports, 1 5/8 runners to a 3" collecter
Hypertech ThermoMaster chip
everything else stock gta material (oil cooler, twin 12" electric fans,ect.)
I apreciate anyone who can help me estimate this thank you guy :]
Old Nov 11, 2010 | 09:35 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: 1988 trans am gta tpi 383 stroker horsepower esitmate
what kind of heads and cam. And did you buy an off the shelf chip for your application?
Old Nov 11, 2010 | 02:21 PM
nutzar4's Avatar
The heads are off a 93 van and have larger valves then a normal 350 head (i dont know the valve sizes offhand) the heads have a stamped II on the sides i also do not know what tht means. As for the cam http://www.summitracing.com/parts/CCA-K12-246-3/ thats all the specs. I dont know what u mean by and off the shelf chip but here is the link for tht also http://www.summitracing.com/parts/HYP-228822/ .
Thank you for your help joe I apreciate it.
Old Nov 11, 2010 | 04:05 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by nutzar4
36# injecters,
Have you run it yet?
Bet it will run like a POS because Hypercrap chip only does minor adjustments and turns on fans earlier.
https://www.thirdgen.org/forums/tpi/...ster-chip.html
https://www.thirdgen.org/forums/afte...jet-chips.html
Does not adjust for the massive injectors you have in there so will be ultra rich (some run 24's in 383 with correct tune )
Need a custom chip tuned to suit cam / injectors
Cam is mismatched because your intake will be dead by 5K but cam goes to 6K .Long runner intakes ( TPI ) do not make power over 5K
Check out
http://xtremecarzone.com.au/index.php?showtopic=386
Heads don't sound like anything special ; even if they were would not overcome the restriction of the TPI intake feeding them
Old Nov 11, 2010 | 09:22 PM
nutzar4's Avatar
Thats what I got the fuel pressure adjuster for. I also have a o2 sensor that reads a/f ratio so i can tune it. I got the chip to erase the stock prom and allow me to be able to use the injectors i needed. I didnt run it yet cuz im wating for a couple other small parts to come in. So make a long story short your saying my engine will not be able to run even with a custom ram air intake system me tuning the a/f ratio with the o2 sensor and fp regulator. The chip is made to bypass the prom cuz if i had the stock prom i would not be able to ajust the a/f ratio and fuel pressure.
Old Nov 12, 2010 | 02:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Most likely you will have to turn the pressure down so low to get A/F right, you won't get correct spray from injectors
Less than 30psi @ injectors = dribble
36's are massively big for a engine of your specs.
I'm making close to 500Hp with 32lb on my 383 w/ 205cc heads/ big cam / and a single plane intake
Old Nov 12, 2010 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is it a wide band O2 sensor ?
If it is a narrow band won't tell anything worthwhile.
NB is only accurate around 14.7AFR ; with your injectors it will be rich off the scale
your saying my engine will not be able to run ..me tuning the a/f ratio with the o2 sensor and fp regulator.
Changing fuel pressure changes fuel delivery across the board.
Does not allow for say; less fuel at idle / cruise and more at WOT
Adjusting fuel pressure allows for minor adjustments from stock tune ; not radical changes like bigger engine ,big cam and big injectors
Don't believe me , ask what tune you need for your specs over in tuning dept
https://www.thirdgen.org/forums/diy-prom/
Hypertech does not allow you to adjust anything different from a stock chip.
It has a fixed tune just like the stock chip ; but different.
Need tuning equipment and software to adjust actual tune
Old Nov 12, 2010 | 02:29 AM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
stock intake? You should maybe get it ported or go with either a loudmouth from ASM or hell even an edelbrock.. but then again I don't know much about this so ...
Old Nov 12, 2010 | 12:48 PM
nutzar4's Avatar
Its a wide band o2 sensor, I had a guy in a machine shop so specializes in stroker moters saying tht i would need 44# injectors minimum to get enough fuel for the engine.
Old Nov 12, 2010 | 05:41 PM
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
We kinda need to know what heads they are... I imagine they are swirl ports but I can't say for sure. It really doesn't matter what size your valves are, bigger isn't necessarily better!
Old Nov 12, 2010 | 06:22 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
Transmission: 4L60 w/ 3200 stall
Axle/Gears: 9 bolt W/370 gear
Wow, the cam that you picked is way too big for your combiation. With the stock intake I would use can with no more than 212 deg dur. @ .050. The stock intake runs out of steam at about 5k rpms with a 350 and even lower with a 383, So a cam with small duration will work better.
Old Nov 12, 2010 | 07:23 PM
nutzar4's Avatar
Eventualy I will be getting a hi-flo manifold, 58mm tb, ect. The more important question i would like to know is if my car will be able to run and drive nicley with my combination.
Thank you guys for the responses
Old Nov 12, 2010 | 08:02 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
44lb injectors are good for 575Hp ( @80 percent duty /0.50 BFSC )
Do the calc yourself
http://www.fuelinjectorconnection.co...widercalc.html
Your combo is not going to come close to that figure
Check the Hp output of the hot 383 ( with way better Perf parts than yours ) in the link I posted above
Good , so you can get accurate A/F feedback.
Adjusting the fuel pressure alone is not going to " tune " the engine
Old Nov 12, 2010 | 08:03 PM
nutzar4's Avatar
Then how could I tune the engine?
Old Nov 12, 2010 | 08:08 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
HSR would be better choice for 383
https://www.thirdgen.org/forums/tpi/...ow-tpi-vs.html
Old Nov 12, 2010 | 08:14 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
You need tuning software , some cables, and a chip burner so you can program a chip to suit
See
https://www.thirdgen.org/forums/diy-...uide-book.html
Or you could get a custom tune from PCMforLess or similar tuner
Just send them your specs and for $210 you have a tune that will at least run
http://www.pcmforless.com/index.php?...per&Itemid=316
Old Nov 12, 2010 | 09:32 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Ditto you need a custom tune, dont let others tell you that cranking the FP up or down will do it or the computer adjusts itself thats BS
Guessingyou have the swirl port heads which hate to say are uh....not great. Pop a valve cover off and post the PN stamped hard to say.
Some porting on the base and good runners would go a long way too.
You could get it running and do that later if you wanted but we all know what fun it is screwing with the TPI once its all togehter.
Need more info.
Old Nov 13, 2010 | 11:02 AM
nutzar4's Avatar
I do not care at this point of reving my car past 5k and racing it, this is a daily driver until i have the money to do all this other stuff. What i want to know is if it will run and drive fine with everything I have not if my combo will make 3million horsepower and 1 second on the quarter mile. I know it is not the right set up yet cuz it isnt done. I need to buy a bunch of other **** like porting the heads, over sized valves, hi flo manifold, 58mm throttle bodies, throttle body spacer, ect. I just want to know if my car will be able to run and drive from a-b without any problems. I apreciate everyones help on saying what i need for max hp but i know this already I just wanna know if it will run fine.
Old Nov 13, 2010 | 11:06 AM
nutzar4's Avatar
vetteoz tht website with the corvette chip or w.e. for 209, will that work for my TA cuz if worst comes to worst and i gotta return my chip, I can always buy that just explain to me how it works a lil more, like the part where i send them my specs and stuff.
Old Nov 13, 2010 | 06:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
will that work for my TA ....just explain to me how it works a lil more, like the part where i send them my specs and stuff.
Check out the order sheet
http://www.pcmforless.com/index.php?...id=2&Itemid=43
You just put your car / engine details in and select things like what temp you want your fans to run / if you want EGR , VATS deleted , etc
Old Nov 13, 2010 | 06:15 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I do not care at this point of reving my car past 5k and racing it, this is a daily driver What i want to know is if it will run and drive fine with everything I have I just wanna know if it will run fine.
In a nutshell ; no without a proper tune.
Not withstanding ,
as has been mentioned cam is too big for heads / intake you are using so may be hard to get tune correct
I apreciate everyones help on saying what i need for max hp but i know this already .
Your missing the point.
The 44 lb injectors you have been told " need " would not be needed on a engine making way more power than what yours will ever make
Old Nov 13, 2010 | 07:07 PM
Tonysz383's Avatar
Car: 88 IROCZ 350
Engine: 355 cu TPI
With your current set up you can't drive the car. You need the chip re-tune to run the 36lbs injectors. I just had my 97 Z ECU re-tune by PCMSFORLESS.COM, I sended the ECU on Monday via Priority mail and got it back on Friday. They are fast.
Old Nov 13, 2010 | 09:11 PM
nutzar4's Avatar
I will return the current chip and get that ones. I kinda knew i needed the custome one but i was afraid that it was gunna cost me 400+ so i thought i could get away with this one. Thats why i sounded like a d**k for earlier but now that i know its like 5 bucks more then the one i got its np and i will deff do tht. Thanks you guys for the help. also very random does anyone know what the speedometer goes up to in a gta digiatal dash?
Old Nov 17, 2010 | 12:14 PM
mightymaro94's Avatar
dont know for sure but being digital with 3 digits i would say 999 lol
Old Nov 17, 2010 | 03:55 PM
nutzar4's Avatar
I figured that but i heard somwhere that it stops at 85mph and starts flashing lmao?
Old Feb 18, 2012 | 11:44 PM
jugheads88gta's Avatar
Car: 89 camaro
Engine: 68-454,87-nothing yet,88gta-305 tpi
Transmission: stock 700r4
Axle/Gears: borg warner 9-bolt/3:27 gears
Haha my 88gta dash went to 117 then my car wouldnt go faster lol twas a stock 305 tpi 170xxx miles but when I turned the car on just befor start it would read 140
Old Feb 20, 2012 | 06:41 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
His hp will be around 275whp. He needs a small cam to work with those heads with a 210 duration under .500 lift.
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
stalkier
Aug 13, 2015 12:59 PM
gta power
Aug 13, 2015 06:15 AM
stalkier
Aug 7, 2015 04:49 AM
