Rocker arm & stud questions
Old Nov 12, 2010 | 04:00 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
While rebuilding my stock 081 cylinder heads I would like to install screw-in studs to support a bigger than stock cam and the required valve springs.
I am planning to go with the Comp Cams RP1417-16 rocker arms. I tried to search which ARP stud I need (134-7101 or 134-7104) but don't really found a clear answer. I think that I should buy the 134-7101, but some clarification from the experienced guys here would be nice.
Other question is that how much should be machined down from the cylinder heads when installing one of those ARP studs having a hex base?
Old Nov 15, 2010 | 02:36 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Re: Rocker arm & stud questions
Anyone?
Old Nov 16, 2010 | 11:05 AM
ian1320's Avatar
Car: 88 IROC-Z and 86 IROC-Z
Engine: TPI 305 and E85/Nitrous 383
Transmission: 700R4 and T56
Axle/Gears: 3:27 and TBA
I would go with the 134-7104. It is the same cost and gives you room to go with a taller spring later if you decide to go with a bigger cam.
That being said why not get 7/16 studs rather than 3/8? They are much stronger and not much more money.
Old Nov 16, 2010 | 11:51 AM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
To be honest, I did not even consider using the 7/16" studs. I just checked the rocker arms for 7/16" studs and it seems that those are at least $100 more expensive than the 3/8" ones. By the way, this is "only" a 305 build so I think that I will be fine with the 3/8" studs.
If I go with the taller stud kit (134-7104) would it cause any clearance issue at higher lifts (0.48-0.49) ? I mean that case when the stud is taller than what my rocker arms really need.
Old Nov 16, 2010 | 02:21 PM
ian1320's Avatar
It should not interfere with the rocker arm geometry at all.
Old Nov 18, 2010 | 01:40 PM
giszo's Avatar
Car: 1992 Camaro RS
Engine: 3.1L V6
Thanks for your help, ian.
Old Nov 18, 2010 | 02:18 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
On the subject of clearances with 7/16" studs; will they, and their respective rockers, fit under stock (with supports clearanced) centerbolt valve covers?
Old Nov 18, 2010 | 05:08 PM
ian1320's Avatar
Every time i have put the money into screw in studs i also get some nice aftermarket valve covers so im not sure if they will fit under stock ones. sorry
SLNTSCPE
Aug 22, 2015 09:15 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
redmaroz
Aug 16, 2015 11:40 PM
