um this doesnt look right?
Old Nov 18, 2010 | 11:55 AM
Xx89CamaroRSxX's Avatar
guess my other post didnt go through. why is the plug bridged like that? is that good or bad for the car?
thanks
Old Nov 18, 2010 | 02:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's to keep the AC running when the Freon is low. Either that, or the switch has failed.
Old Nov 18, 2010 | 06:41 PM
TunedPort350's Avatar
Car: 88 GTA, 91 GTA, 92 T/A vert
Transmission: 6 speed & 700 r4's
Re: um this doesnt look right?
Like the five7kid said, that is jumpering the low pressure cut-out switch for the air conditioning compressor. The only time you want that on is when you are putting the initial can or two of freon in the system when there is no freon (or pressure) in the system.
You shouldn't leave that hooked up permanently. If there is a bad switch replace it. Otherwise if your system gets low on freon, it will not circulate enough oil to the compressor and you will end up ruining it.
Old Nov 18, 2010 | 08:43 PM
alright thanks guys ill hook it back up. plus how do i know if the switch is bad?
Old Nov 18, 2010 | 08:48 PM
mightymaro94's Avatar
you definitely dont wanna leave it like that... compressors arent cheap and you dont know they are bad until you fill em full of freon
Old Nov 19, 2010 | 06:24 AM
SoCo80p's Avatar
like mentioned you only jump like that when the freon is low during recharge, running it like it is will cause damage. Pull it off right away.
Old Nov 19, 2010 | 02:13 PM
five7kid's Avatar
Hook up a pressure gauge. If the pressure is high enough and the switch is open, the switch is bad.
I don't know the proper pressure off the top of my head.
Old Nov 19, 2010 | 02:26 PM
89-bird's Avatar
Car: Firebird
Engine: 2.8 v/6
Transmission: t/5
Axle/Gears: open/3.42
IIRC it should be around 35lbs on the low side but only 150lbs on the high side IIRC .
