Engine combo
Old Nov 18, 2010 | 04:55 PM
The_F_body_kid's Avatar
Car: 85 z28
Engine: 410 CI
Transmission: 700 r4
Axle/Gears: 373
Engine combo
Ok Guys need some help here this is what im currently puting together
-406 small block .30 over (stroked as well)
-comp cams xe268 .477/.480 224/230@.050 (flat tappet)
-Magnum 1.52 Full Roller rockers
-AFR 195 street eleminators with 65cc chamber
-victor junior intake
-750 double pumper (holly) of course
-2500 Stall
-373 gears
-rebuilt 700 r4 tranny
-1 5/8 inch headers
-catless magnaflow exaust
-auburn posi
-car is an 85 z28
- max rpm will be about 6200
I dont want to get my hopes up on power but is 420 hp and 470 tq do-able with this combo if not tell me what direction that i need to go
-my main focus is on torqe i want to prety much want to murder my tires at will
-any help is so much appreciated
thanks
Old Nov 18, 2010 | 07:37 PM
Car: 85 z28
Engine: 410 CI
Axle/Gears: 373
Re: Engine combo
Please help
Old Nov 18, 2010 | 08:52 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine combo
Originally Posted by The_F_body_kid
Please help
I reckon it will fall on it's **** at revs.
You have a big breathing top end setup ;
Heads /Intake / carb good for 7000+ ( Vic Jnr recommended operating range 3,500 - 8,000 )
while your cam operating range is ;1,800-5,800 ( in a 350 , lower in a larger engine)
So why have you picked a intake / carb combo that works at big revs.
A Air Gap or similar intake would make better power down low without killing top end
What stroker crank do you have?
A 30 over 400 is 406 .
IF it is stroked it would be larger.
Old Nov 20, 2010 | 09:11 AM
LS4GXP's Avatar
Car: 87 Z28
Engine: AFR 383
Axle/Gears: 4:11
Re: Engine combo
i would agree, needs more lift, tad more duration, atleast a 3k stall, and change the intake to a RPM air gap. Also put your goals higher then 420hp
Old Nov 23, 2010 | 01:23 PM
Car: 85 z28
Engine: 410 CI
Axle/Gears: 373
Re: Engine combo
thanks guys im very new to this and i appreciate all of the help i think it should run good
Old Nov 23, 2010 | 01:26 PM
mightymaro94's Avatar
Re: Engine combo
yea you should def. match head intake and cam... for your purpose and each other
Azrael91966669
25
Jun 20, 2017 04:04 AM
IMissMy86TA
Aug 31, 2015 08:40 PM
nuggie
Aug 25, 2015 01:27 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
