rebuilding 350: can't turn crank
Old Nov 21, 2010 | 01:23 PM
MikeSammy's Avatar
Car: 1986 Pontiac Firebird
Engine: 357ci 400hp 4BBL
So this is the problem I am runnign into. I was rebuilding my 350. I rerung the pistons and put all new bearings in. The crank was ground .010 so I had .010 bearings. The crank turns freely with no piston on it. The crank will turn with the pistons hand tighnted to it, but when I torque the bolts the crank will no longer turn. I pushed so hard to turn the crank the engine stand almost flipped over. I only torqued to bolts to 35 even though they are supposed to torqued to 45 since they are 9/16 nuts on them. When loose the crank turns easily. I did oil the cylinder walls, bearings, pistons, and crank.
Old Nov 21, 2010 | 01:27 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
Re: rebuilding 350: can't turn crank
It's always better IMHO to measure all clearances with plastigage. There may be something wrong with the clearances, ex. wrong size bearings? It's not supposed to be that hard at all.
zraffz's Avatar
Car: 1994 Z28
Engine: 355 LT1
Sounds like something is wrong with the rod bearings.
Not to mention a rotating assembly without heads on it and no accessories should turn very easily... all you are moving is the rotating mass, you shouldn't be fighting much friction.
Old Nov 21, 2010 | 01:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What was ground .010? The mains, or the pins?
Old Nov 21, 2010 | 01:37 PM
MikeSammy's Avatar
all parts for the engine, besides cam, were ground .010. I have a set of standard bearings for the pistons, should I try these
Old Nov 21, 2010 | 01:48 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
What are you using to lube the bearings? I used this stuff http://www.summitracing.com/parts/SLP-55-400/?rtype=10 and it was so sticky the engine got very hard to turn.
Old Nov 21, 2010 | 01:51 PM
MikeSammy's Avatar
I use regular engine oil. For the cam I had used this oil that was sticky and now I can't turn the cam either. So for the pistons I just stuck with regualr engine oil
Old Nov 21, 2010 | 01:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
No, you should measure the parts first to check to see what the specs are. Then use the appropriate bearings with plastigauge to check clearances. When installing the rods and pistons, do one at a time and check rotational torque after torquing the rod bolts. Each piston should add a few more pounds of torque. Something like 10 pounds per piston. One or all rod bearings may be too tight. Checking each rod as it's installed can let you know if one is too tight.
Are the rods installed on the crank properly? The chamfered side of the rod goes to the side of the crank journal as does the rod bearing. The pistons/rods need to go into the cylinder properly. It's easy to mix them up, install a piston/rod upside down, wrong side etc.
Old Nov 21, 2010 | 02:02 PM
scamaro355's Avatar
Car: 92 rs
Engine: 355 stealth ram, dart heads, S480
Transmission: 4L80E
so what were your bearing clearances on the rods bearings?
Old Nov 21, 2010 | 02:04 PM
MikeSammy's Avatar
I had read in a book that on the pistons with the 4 reliefs the little notch on the side must go toward teh front of the engine where the timing gear are. Should I put it the other way.
Old Nov 21, 2010 | 02:12 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
That's right, but you have to make sure you have the right bank pistons on the right side and the left bank pistons on the left side. When properly installed the rod bearing tangs will be pointing "down".
Old Nov 21, 2010 | 02:39 PM
MikeSammy's Avatar
Well not all the rod bearing tangs point down, but I had put the pistons back the way I took them out. I heard that you must put the pistons back in their respecive bores.
Old Nov 21, 2010 | 02:49 PM
scamaro355's Avatar
Car: 92 rs
Transmission: 4L80E
yeah as long as the pistons arent new in an old bore... alot of time the bore will go slightly egg shaped over time
Old Nov 21, 2010 | 03:08 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You've done something wrong. The rod bearing tangs must all point down.
Old Nov 21, 2010 | 03:20 PM
Grumbles's Avatar
Car: 1978 Chevrolet impala
Engine: 350ci 300hp/356tq pace crate
Axle/Gears: 3.42 Yukon posi
Sorry to chime in and hijack but what the hell is a rod bearing tang?
Old Nov 21, 2010 | 03:36 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The little bump in the edge of each bearing half that fit into the notches in the cap to keep the bearings from spinning.
Old Nov 21, 2010 | 04:02 PM
MikeSammy's Avatar
I guess who ever owned the engine before me put them in wrong. Tomorow I will remove all the pistons and check for any problems.
Old Nov 21, 2010 | 08:58 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Bet a rod cap isnt on straight. THey can appear to be but if they are off just the slightest bit the bearing can bind up, can also do it if the rod is torqed down and the rod isnt straight in the bore (there will be a little side to side play) Force it and youll damage something. Double check an assembled rod to check the sizing of it..put the beaing in measure again, measure the crank then subtract the clearance to see what you have. Check measure and check again
Do one rod ata time then rotate the motor
Old Nov 22, 2010 | 06:45 PM
mlynch001's Avatar
Car: 1985 El Camino SS, 2004 Trailblazer
Engine: Hybrid 305, 91 SD TPI, lots of mods
Transmission: 200-4R
If they mixed up the pistons and had them in backwards, they may have mixed up the rod caps. Are the caps and rods numbered? I would check the big ends of the rods to make sure they are not out of round or mixed up. GM did not number the rods and caps, you have to do that when you tear down. Rod caps go on with the bearing tang in the rod and cap on the same side of the rod.
Install one rod at a time. Torque the cap and see if the rod will slide freely from side to side. If it will not slide then you have a problem with that rod. Do one side at a time, and check each one as you go.
Old Nov 24, 2010 | 08:15 PM
MikeSammy's Avatar
if I have tghe engine on an engine s tand and it is upside down, looking at the engine standing from the front, then the bearing tangs should be on the left for the left side and and the right for the right right, am i correct.
Old Nov 24, 2010 | 09:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
They'll be facing "up" with the engine upside down, or you could think of it as them facing "out" towards the outside of the block, as well.
Caspar
Jun 19, 2016 11:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
Jae992
Aug 27, 2015 09:07 AM
Bryan F
Aug 18, 2015 02:28 PM
hokis
Aug 9, 2015 03:57 PM
