Oil everywhere.
Old Nov 30, 2010 | 08:50 PM
DeCaff2007's Avatar
Oil everywhere.
Hey all.
So I just got my 91 Firebird put back together and she starts and runs quite nicely.
Now, I have another issue. When I first saw it, I didn't think it was that bad, however, I took a second look and there is oil dripping (maybe 1 drip every 2 seconds) from where the bell housing meets the block.
A friend of mine said the rear main seal is toast. I'm half inclined to believe him due to his experience as a mechanic, however, that doesn't mean that I can't get the forums advice.
Anyone here agree, or do I have a totally different issue? If it's the rear main, how much of the PITA am I going to have replacing this?
Thanks in advance.
Old Dec 1, 2010 | 04:10 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Oil everywhere.
2 spots that could be leaking back there:
1. rear of intake, really common leak point especially if a gasket was used on the china wall instead of rtv
2. rear main seal.
start from the top of the engine; if you can feel oil from up there, its the rear of the intake. if you can only feel it underneath the bellhousing, its the rear main
Old Dec 1, 2010 | 04:12 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: Oil everywhere.
Another spot to check while you are looking is the port in the top rear of the block. I'm not sure if you application merely has a plug, or is used for an oil pressure sender, but regardless they like to leak from there as well.
Old Dec 1, 2010 | 05:39 PM
torque_is_good's Avatar
Re: Oil everywhere.
if it's the rear main, before you drop the tranny to get to it, try a bottle of white shepherd rear main sealer. It's $13 at Amazon and worth the try. No, it's not sludge that causes future problems.
Old Dec 1, 2010 | 05:46 PM
DeCaff2007's Avatar
Re: Oil everywhere.
I didn't notice anything there. The oil pressure sender is right above and just behind the oil filter. I know because the one my engine came with was physically broken and I had to replace it.
I'll check that area you are talking about, though.
Also, torque_is_good: While I very much appreciate the advice, I have no problem tearing the tranny off. It takes me all of 45 minutes.
Well, this weekend is supposed to rain worse than Niagara Falls, but I'll be out there, under a tarp, fixing this (among other things) just because I'm insane. As long it's not below freezing, life will be good.
Old Dec 1, 2010 | 06:21 PM
alexsholly's Avatar
Car: 91 rs
Engine: 305 tbi
Re: Oil everywhere.
i have the same problem just payed bout 200 for the rear main seal to be replaced and it seems it leaks worse now lol. how much wuld it usually cost for a intake gasket replacment i dont have the time to do it myself ive heard it culd cost only 200 then aall the way up to 500 so i neeed about an guess on time involved so when i take it to the shop i kno they wont try to screw me
Old Dec 1, 2010 | 07:18 PM
DeCaff2007's Avatar
Re: Oil everywhere.
Intake gasket was a piece of cake, actually. I may have used an insufficient amount of RTV on the rear seal of the intake manifold, however. It would be very awesome if this is the case. It would turn a 3 hour job into a 30 minute job.
Old Dec 1, 2010 | 07:30 PM
thewizard's Avatar
Re: Oil everywhere.
The port I'm referring to is on the top ridge of the block directly behind the IM. It's a 1/8 NPT pitch. In the older (Pre 88 I THINK) it was used for the oil pressure sending unit for the gauge. In your year it should have a plug due to the gauge and ECU signal coming from the sender you replaced.
Old Dec 1, 2010 | 08:52 PM
DeCaff2007's Avatar
Re: Oil everywhere.
I see. I'll look back there this weekend when I have some time. By the time I get home from work, it's too dark out and I'm too pooped to do anything car related.
FormulasOnly
Jul 23, 2018 08:47 AM
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
