View Poll Results: How did your HV pump cause the pan to drain?
I screwed up during my build and blamed it on the HV pump.
16.67%
Another part failed and I blamed it on the HV pump.
0%
I forgot to put oil in and I blamed it on the HV pump.
0%
I forgot to put the drain plug back in the pan and blamed it on the HV pump.
0%
I blocked the pump bypass spring to increase pressure and ran the sump dry.
0%
I blocked/didn't clean the head/valley drain holes and ran the sump dry.
0%
My friend/machinist/hairdresser told me the HV pump sucked the pan dry.
50.00%
I don't understand how the oiling system works.
33.33%
Voters: 6. You may not vote on this poll
Everyone who has drained the pan with a high-volume oil pump
Old Dec 9, 2010 | 09:26 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I just saw mention of this again in another thread, so lets get to the bottom of it.
Please choose one of the poll options.
Old Dec 9, 2010 | 09:35 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Everyone who has drained the pan with a high-volume oil pump
LMAO!!!
Good stuff there. Pull my hair out when I read cautions about sucking the pan dry..geesh.
Old Dec 9, 2010 | 09:53 AM
Twin_Turbo's Avatar
This is from the same source as the back pressure is good tale.
Old Dec 9, 2010 | 10:56 AM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Transmission: 700-R4
Axle/Gears: 4.10
My "friend/machinist/hairdresser" also told me this is why my valve cover leaked profusely. Too much oil up there and not enough in the pan.
Old Dec 9, 2010 | 11:07 AM
Twin_Turbo's Avatar
Well at least there's a little truth to that, it's a known fact that SBCs tend to collect quite a bit of oil in the rocker boxes, thats why improving drain helps a good bit there
Old Dec 9, 2010 | 12:01 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It leaked because it wasn't sealed. If it leaked with an HV pump, it would have leaked with a standard pump.
Old Dec 9, 2010 | 12:27 PM
DNSTA's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 4.10
I agree with both of you! I assume improving the drain-back means boring out the holes in the head correct?
Old Dec 9, 2010 | 12:43 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Cleaning up the flash, smoothing out the casting around the holes. You can smooth or paint the lifter valley as well. The main advantage to both of those is to minimize the amount of time the oil stays in contact with the hot heads and block, not to keep the volume in the pan up.
Old Dec 9, 2010 | 03:09 PM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
what no option for never running a HV pump?
Old Dec 9, 2010 | 03:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Good point... a sizable proportion of the promoters of the idea that HV pumps drain the pan have never run one.
Old Dec 9, 2010 | 03:48 PM
Sparkytfl's Avatar
Car: 85 TA (sold), 88 Corvette, 02 Monte
I havent noticed any draining of the oil, and I'm crazy enough to be using a big block pump.
Old Dec 9, 2010 | 04:19 PM
Kat's Avatar
Kat
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Never ran the pan dry but collapsed a few oil filters..
Old Dec 9, 2010 | 05:51 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
When youve spent $1000s building a high performance motor just to see it spin a bearing due to insufficient oiling, youll understand the value of the HV oil pump.
Old Aug 16, 2013 | 07:38 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Thought I would just post this picture to aid in your explanation. The oil drain holes are at the front and rear corners of the blocks/heads. Make sure that the drain holes between the heads and block line up and not misaligned. I polish all of the sides of the lifter valley but I don't polish the center of the lifter valley because the lifter bores create little oil pools that without angling the block up or down significantly will always be there. You can radius and port/enlarge the oil drain holes in the center of the valley so there is virtually no oil sitting in the valley but virtually every source I have read says that (for our roller cam engines) it is best to block or greatly restrict those holes via pipe plugs/restrictors/standoffs.
Attached Thumbnails Everyone who has drained the pan with a high-volume oil pump-383-block-prep-7.jpg
Old Aug 16, 2013 | 07:42 PM
Tibo's Avatar
Car: 1991 Z28 Vert
You can also extensively enlarge and put a liberal radius on the front oil drain holes. The stock holes are positioned with nearly 1/2" between the bottom of the drain hole and the lifter valley floor, allowing oil to pool a bit before any draining occurs. I'm sure you could enlarge the holes even more than I do but I don't know enough about block strength to go bigger.
Attached Thumbnails Everyone who has drained the pan with a high-volume oil pump-383-block-prep-6.jpg
Old Aug 16, 2013 | 08:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Looks great Tibo!!
I like the dizzy end returns-- attention to detail!!
Old Aug 17, 2013 | 10:56 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
HV pump has been known to be the cause of a spun bearing.
Worn cam bearings, worn timing gears and worn out dist. gears.
The only reason to ever run one is if you have a bleed off like a turbo or a supercharger.
It all came to pass in the old days when we ran excessive bearing clearances, but soon learned that was not a good idea.
Old Aug 17, 2013 | 12:19 PM
Tibo's Avatar
Car: 1991 Z28 Vert
I believe that Apeiron was referencing this thread ( https://www.thirdgen.org/forums/tech...e-vs-high.html ) that was referencing this article ( http://www.carcraft.com/techarticles...s/viewall.html ) by Car Craft. It seems to be a worth while article that really calls into question the whole high volume or pressure pump wiping out bearings.
Old Aug 17, 2013 | 02:30 PM
project89's Avatar
hi volume high presure pumps will no wipe out bearings
the engine in my turbo v6 camaro runs 65#'s op at idle hot and over 105# at redline hot
that engine has over 100k on it and is abused daily, bearings still look as good as the day i put them in
Old Aug 18, 2013 | 01:17 AM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I had always heard about a HV pump sucking the pan dry and never believed it till I put one in a 93 Z28 I build for a friend. Top of second gear @ WOT it would loose oil pressure everytime. Put in a standard pump and never had a problem since.
Old Aug 18, 2013 | 11:57 PM
Car: '87 Camaro
I had a HV in my bigblock & never had a problem...
This is interesting...
Old Aug 19, 2013 | 11:01 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Way better answers to this over on speedtalk.com
HV pumps, poor drain back and stock size pans are a good idea on high rpm quick rev'n SBC and SBF motors.
There is a need for HV pumps on older motors with larger bearing clearances but todays motors not so much.
Waaaay to many variables to just say one pump is the best for everything.
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
xxx3man`
Sep 23, 2015 10:37 PM
Navy8125
Aug 21, 2015 09:32 AM
